VS 2008 on 64-bit VISTA
Escarela-Perez__Rafa
Hi everybody,
I am having problems to integrate IVF with VS 2008 on Vista (64 bits). First, there was no integration at all. Then I run the program repairvs08integration.exe provided by Steve Lionel. I was then able to see an integration of the 32 platform. However, I can't see the 64 platform and the fortran compiler. VS 2008 reports that the x64 compiler is not installed, which is fasle. I have reinstalled the compiler using w_fc_p_10.1.025_Intel64 and w_ide_p_10.1.025_IA32 in the C:Program Files (x86)IntelDownloadIntelFortranCompiler10.1installs directory but nothing happens. Does any one have any idea about this behaviour?
Best wishes,
Rafael
You probably do not have the X64 support installed - it does not install by default in VS2008 Professional Edition and higher. Go into Add or Remove Programs, "Change" VS, and select the Visual C++ > X64 Compiler and Tools component. Then reinstall the Fortran compiler.
Thanks a lot, you were right as usual.
Rafael
