We have solutions with mixed C++ and fortran projects. We have many crashes when cleaning the projects either by doing clean solution, or just by cleaning one project by itself. However, it is not consistent and i can not reproduce it in a small solution that i could send. When a project clean is crashing, i could just clean other projects and come back to the first one and it would not crash anymore.
This only happen on fortran projects, not the C++ ones.
Looking at the logs do not say anything. And if i attach a debugger to the visual studio crashing, the process return a value of 0xC0000005 so random memory issue.
Even for projects that can be cleaned without crashing, i always have a first-chance exception logged in my debugger:
"A first chance exception of type 'System.NullReferenceException' occured in Microsoft.VisualStudio.CommonIDE.dll"
Update 12 of the XE 2011 compiler gives me even more of those crashes than with update 10 which i was using before.
Has anyone encountered such an issue and found a workaround?
Brian Francis
