28455 Discussions
Value of epsilon result differs from manual
CHobbs1
All;
I wrote this program:
Real*4 rsingle
Real*8 rdouble
rsingle = epsilon(rsingle)
rdouble = epsilon(rdouble)
Write(6,*)'rsingle = ',rsingle
Write(6,*)'rdouble = ',rdouble
Pause
And got this result:
rsingle = 1.1920929E-07
rdouble = 2.220446049250313E-016
Fortran Pause - Enter command<CR> or <CR> to continue.
The manual entry for epsilon ends with:
Example
If x is of type REAL(4), EPSILON (X) has the value 2 -23.
Why is the difference betweeen 2^(-23) and what is written to the screen so big?
All help on this appreciated.  Thank you.
Arjen_Markus
Honored Contributor I
Why do you think there is a big difference? The numerical  value of 2^(-23), when written in decimal form (what you get with write(*,*) is approximately 1.1920928955078125e-7. So, apart from a few extra decimals, that is quite the same value.
The only difference I can think of is the form in which these numbers are presented. But that is the presentation, not the actual value.
Arjen_Markus
CHobbs1
  • My bad.  I typed it out on the calculator wrong and failed to double check it.  Thank you.
Arjen_Markus
No problem - it happens to al lof us from time to time. One time I tried to solve a problem in a program and I was sure I had it fixed but still got the erroneous behaviour, only to find out an embarrassingly long time later that I had been running an old version ...
jimdempseyatthecove
My wife complained to me that I couldn't balance our check register...
... after looking at the numbers I realized I was using base-8 arithmetic.
Jim Dempsey
