29657 Discussions
Viewing declared variables during debug session
Don_Shirey
I have been able to compile in debug mode. However, I am unable to view the values for the variables being used. For example, I have a subroutine where a real variable is declared (r64). I place a breakpoint on the line after the value is calculated. I try to hover over the variable name with the cursor to view the calculated value.. but no value is displayed. I tried to add the variable to the watch box, and it says "Error: symbol "" not found."
I am using the following:
Microsoft Visual Studio 2008, Version 9.0.30729.1 SP
Microsoft .NET Framework version 3.5 SP1
Intel Visual Fortran Package ID: w_fcompxe_2011.4.196
Intel Visual Fortran Composer XE 2011 Integration for Microsoft Visual Studio* 2008, 12.0.3471.2008, Copyright (C) 2002-2011 Intel Corporation
Various service packs to VS 2008 professional edition
Any suggestions?
Anonymous66
Valued Contributor I
If you want to see variable information, set "Properties > Fortran > Debugging" to "Full(/debug:full)" instead of "Line Numbers Only (/debug:minimal)"
Don_Shirey
Thanks, that worked!
