29333 Discussions
Visual Studio 2005 Abort follows Fortran Code
mattintelnetfort
Has anyone seen anything like this? Any ideas?
If the following Fortran source file is is used to create an executable (i.e., EXE), Visual Studio 2005 crashes (closes unexpectedly) when a breakpoint is added to the only executable line in the source file. To reproduce:
1) Create an empty Fortran console project.
2) Add the attached source file as the only source file in the project. Note there is a PROGRAM, and a SUBROUTINE with supporting ENTRY in the single source file. Also note that the subroutine is not even called from the main program (though the result is the same if it is called).
3) Build the debug configuration.
4) Run the executable built (no runtime arguments required). Note the console window will open and sit waiting for input.
5) With the console window waiting for input, place a breakpoint in the source file at the only executable line of code (i.e., "I20=0"). >> Now watch while Visual Studio crashes!
This test program represents a problem observed in our production application. The following observations have been noted regarding the Visual Studio crash:
1) If the test program is modified to remove the argument to the entry point, the crash described does not occur.
2) If the leading argument to the subroutine is removed from the argument list, the crash described does not occur.
3) If the trailing argument to the subroutine is removed from the argument list, the crash described does not occur. Note additional arguments can be added after the current last argument in the list and the crash still occurs.
4) If arguments R10 and R11 are removed from the argument list, the crash described does not occur.
5) No build settings changes could make this work.
PROGRAM TESTPROGRAM
read(5,*) i8
END
SUBROUTINE ROUTINE1(I1,RA1,DA1,IA1,DA15,IA2,IA3,IA4,IA5,IA6,IA7,
1 IA8,IA9,IA10,IA11,IA12,IA13,IA14,
1 IA15,IA16,IA17,DA2,DA3,DA4,DA5,RA2,
1 NA1,IA18,IA19,DA6,IA20,IA21,IA45,IA46,IA47,
1 IA22,IA23,IA24,IA25,IA27,IA26,IA28,IA29,DA7,
2 I2,I3,I4,I5,I6,I7,I8,IA30,
3 R1,R2,R3,R4,R5,R6,RA3,R7,I9,I10,I11,I12,
4 I13,LA1,IA31,IA32,IA33,I14,I15,
5 IA34,I16,D1,R8,R9,I17,I18,IA35,
5 DA8,DA9,DA10,DA11,I19,R10,R11,
5 IA36,DA12,DA13,IA37,IA38,IA39,IA40,
5 IA41,IA42,IA43,IA44,NA2,DA14)
C
IMPLICIT REAL*8 (A-H,O-Z)
REAL*8 DA15(1),DA2(1),DA3(1),DA4(1),DA5(1)
INTEGER*2 NA1(1)
REAL*8 DA1(1),DA8(1),DA9(1),DA10(1),DA11(1)
DIMENSION IA2(1),IA3(1),IA1(1),IA5(1),
1 IA4(1),IA15(1),IA16(1),IA36(1),IA20(1),IA17(1),IA18(1),
2 IA7( 1),IA8(1),IA9(1),IA10(1),IA6(1),DA6(1),IA30(1),
3 IA45(1),IA46(1),IA47(1),IA22(1),IA23(1),IA24(1),IA25(1),
5 IA26(1),IA28(1),IA29(1),DA7(1),IA19(0:300),IA21(1),IA27(1),
5 IA11(1),IA12(1),IA13(1),DA12(1),DA13(1),IA37(1),
7 IA38(1),IA39(1),IA40(1),IA31(1),IA32(1),
8 IA34(1),IA33(1),IA35(1),
9 IA14(1),DA14(1)
REAL*4 RA2(1),R1,R2,R3,R4,R5,RA3(1),R7,RA1(0:1),R8,
1 R9,R6,R10,R11
LOGICAL*1 LA1(1)
DIMENSION IA41(1),IA42(1),IA43(1),IA44(1)
INTEGER*2 NA2(1)
I20=0
RETURN
ENTRY ENTRY1(I21)
RETURN
END
I suggest reporting this to Intel Premier Support.
