29650 Discussions
Visual Studio 2005 Dialog Editor does not support drag from toolbox and drop into dialog box
warwickb1
In a Visual Studio Project I have a Wizard-created dialog box showing [Apply] and [Exit] Buttons. I would like to add a Text Box item and a "Edit Control" item from which to extract input from a user into an IVF program. Unfortunately I can't drag and drop any item from the toolbox onto the dialog box. If I try "cut and Paste", I seem to be able to Copy but I certainly can't Paste.
Is there a simple instruction in VS that simply enables drag and drop from the "Dialog Editor" toolbox onto a dialog box, or is there another issue? I have re-loaded VS2005 but it didn't make any difference.
I am using VS 2005 in an XP-SP2 environment.
You need to install Service Pack 1 for VS2005. This will fix the problem.
