29641 Discussions
Visual Studio 2017 debug crach when showing array
jansson
Me and my co workers all have an annoying problem with Visual Studio crashing when we expand an array while debugging a program. Its reproduced by this program.
    program Console1
    implicit none
    ! Variables
    double precision array(1)
    ! Body of Console1
    array(1)=1
    print *, 'Hello World'
    end program Console1
I made a new Project with an "Intel Visual Fortran" "Console Application" with "Main Program Code" from VS File New menu. Only change was adding a array variable. Built it in default Debug x86, and run.
If I hoover the mouse over the array variable I get the the small tool tip
But when I try to click the small arrow to show the values of the array Visual Studio first first seem to freeze then crash.
I can "nail" it to the code, but then expanding the array cause a crash.
If I click the Locals window I get a Crash.
Though, I am able to show values of arrays in Watch window.
Is it possible to disable this popup tool tip for arrays?
Can you reproduce this? Suggestions?
Cheers,
Magnus
My Setup:
I use Windows 7
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on IA-32, version 18.0.3 Package ID: w_comp_lib_2018.3.210
Below is all VS2017 info:
Microsoft Visual Studio Professional 2017
Version 15.8.2
VisualStudio.15.Release/15.8.2+28010.2016
Microsoft .NET Framework
Version 4.7.02558
Installed Version: Professional
Visual C++ 2017   00370-20008-15536-AA629
Microsoft Visual C++ 2017
ASP.NET and Web Tools 2017   15.8.05077.0
C# Tools   2.9.0-beta8-63208-01
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Intel® Parallel Studio XE 2018 Update 3 Composer Edition for Fortran Windows*   Package ID: w_comp_lib_2018.3.210
Intel® Parallel Studio XE 2018 Update 3 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2017, Version 18.0.0040.15, Copyright © 2002-2018 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
JavaScript Language Service   2.0
Microsoft JVM Debugger   1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft MI-Based Debugger   1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards   1.0
Microsoft Visual Studio VC Package   1.0
MLGen Package Extension   1.0
MLGen Package Visual Studio Extension Detailed Info
NuGet Package Manager   4.6.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
ProjectServicesPackage Extension   1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Test Adapter for Boost.Test   1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test.  The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test   1.0
Enables Visual Studio's testing tools with unit tests written for Google Test.  The use terms and Third Party Notices are available in the extension installation directory.
Visual Basic Tools   2.9.0-beta8-63208-01
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual C++ for Linux Development   1.0.9.27924
Visual Studio Code Debug Adapter Host Package   1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Tools for CMake   1.0
Once I got this stack trace from VS:
System.NullReferenceException
  HResult=0x80004003
  Message=Object reference not set to an instance of an object.
  Source=Intel.CommonTools
  StackTrace:
   at Intel.CommonTools.Annotations.AnnotationFactory.get_provider()
   at Intel.CommonTools.Annotations.AnnotationFactory.TryInit()
   at Intel.CommonTools.Annotations.AnnotationFactory.<.ctor>b__16_1(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
mecej4
What you have discovered may be yet another incompatibility of VS2017 versions more recent than the latest supported version, which is version 15.6 (you reported 15.8.2). Please see https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/784330#comment-1926418 .
mecej4
Steve_Lionel
This is a reappearance of an issue that was resolved in 18.0.3 with an older VS2017 update. but broke again with a newer VS17.
jansson
Thank you for the fast answer!
