Visual Studio SP1 Crash on exit
AndrewC
New Contributor III
I have a Visual Studio 2005 (SP1) solution with mainly C/C++ projects but one Fortran project ( I am using 9.1.034)
And I did uninstall all Intel products before upgrading to SP1
Everytime I exit Visual Studio I get a crash in Visual Studio, the stack trace points the finger at the VFTool integration.
Any ideas?
> VFToolOpt.dll!081cb7f9()
[Frames below may be incorrect and/or missing, no symbols loaded for VFToolOpt.dll]
VFToolOpt.dll!081cda89()
VFToolOpt.dll!081c1b61()
VFToolOpt.dll!081c1ab2()
msenv.dll!501ab856()
msenv.dll!501a84b9()
msenv.dll!501a5a36()
msenv.dll!501a59a4()
msenv.dll!501c90e4()
msenv.dll!500f336a()
msenv.dll!5006e90c()
msenv.dll!500cb027()
msenv.dll!506ee942()
msenv.dll!50004dd9()
kernel32.dll!7d4e30c6()
kernel32.dll!7d505426()
msenv.dll!500f543a()
devenv.exe!0040a4a9()
devenv.exe!004068cf()
I haven't seen this. Please create a ZIP of your solution folder and attach it to a problem report sent to Intel Premier Support. We'll be glad to take a look.
AndrewC
New Contributor III
I've submitted a bug report. But the usual problem - our solution folder, zipped, is huge and proprietary.
Perhaps your support team could send a debug version of the DLL with PDB. Then we could isolate the exact location of the crash in your DLL. That often is a big clue to the problem.
That's not helpful in this sort of a problem. However, the actual source files are probably not needed - just the .sln, .suo, .vfpoj and .vcproj files. It may well be that the Fortran support DLL is just "an innocent bystander".
kent_myers
We have exactly the same problem. We described it before.
http://softwarecommunity.intel.com/isn/Community/en-US/forums/post/30229931.aspx
No solution yet?
Please give me the number of the Intel Premier Support problem report you submitted. I'm unable to find a matching report.
AndrewC
New Contributor III
The only solution we found was to take the VF projects out of the solution (:
I was not able to give Premier Support a reproducible example
kent_myers
It only happens with one (main) solution. It has16 projects, one is Fortran, the rest are C++. Another thing, if you just choose "Close Solution" and then leave it for a while, then close, it may not crash.
AndrewC
New Contributor III
Your setup is very similar to ours ( one FORTRAN project, multiple C++ projects). The bug was killing us as our automated builds kept failing with a studio crash. Breaking out the FORTRAN projects was the only solution in the end.
jackosullivan
VFtool might be the villain. Their current home page ( http://www.vftool.com/)shows that their 03/22/2007 Release 2.20 " Fix[es] a bug - if the .dsp file contains non-existing file, VFTool will on longer close DevStudio."
Do you users of VFtool consider it a worthwhile purchase?
Thanks and God bless!
Jack
John4
Valued Contributor I
According to the home page's FAQ, VFtool is not supposed to work on any Visual Studio.NET version.
As was discussed in comp.lang.fortran a while ago, DVF/CVF already had most of the functionallity that VFTool was supposed to add ---so when people buy the VFtool add-in, they're essentially paying for the discovery of what they already have.
...And maybe that's why VFTool is not yet supported in the VS.NET versions ---i.e., IVF does not have source browsing/intellisense support yet.
John.
Jugoslav_Dujic
Valued Contributor II
I think there's a misunderstanding going on here: the "VFtool" in the original post refers to standard Intel Visual Fortran integration component, residing in:
C:Program FilesMicrosoft Visual Studio 8Intel FortranVFPackagesVFToolOpt.dll
...and not to www.vftool.com, which is a 3rd-party program.
We did find and fix a problem that sounds similar to this. Please let us know if the problem remains in version 10.0.
jackosullivan
Thanks very much, Jugoslav, for straightening me out ... and for all your terrific help in the forum.
Thanks, too, John, for the info on VFTool.
God bless!
Jack
