Has anyone else encountered this and resolved it? If so, what is the resolution?
Thanks!
and/or have you opened a vfproj file from VS2010 since the update?
And do you have different versions of VS on the system?
if it only happens on a double click from Windows i'd guess it's an issue with opening the wrong version of VS??
I get the same error when I double-click the project file to open,and when Iopen VS2010 first andthen open the project from there, and also when using the context-menu using the "Open With" command pointing to VS2010.
This error occurred immediately after updating the fortran compiler on the first attempt to open the project. It is consistent in that it occurs every time I open the project. I can click "OK" on the dialog box to close the error message and then continue to work with no apparent ill-effect.
I have VS2008 installed but have been using VS2010 exclusively for some time now with no problems.
This behavior has occurred on 2 independent systems but both with Windows 7 64-bit OS and VS2010 immediately after updating to the latest fortran compiler.
Wendy
Intel Developer Support
Here is the information from VS2010 Help => About:
Microsoft Visual Studio 2010
Version 10.0.30319.1 RTMRel
Microsoft .NET Framework
Version 4.0.30319 RTMRel
Installed Version: Professional
Microsoft Office Developer Tools 01018-587-3345904-70071
Microsoft Visual Basic 2010 01018-587-3345904-70071
Microsoft Visual C# 2010 01018-587-3345904-70071
Microsoft Visual C++ 2010 01018-587-3345904-70071
Microsoft Visual F# 2010 01018-587-3345904-70071
Microsoft Visual Studio 2010 Team Explorer 01018-587-3345904-70071
Microsoft Visual Web Developer 2010 01018-587-3345904-70071
Crystal Reports Templates for Microsoft Visual Studio 2010
Hotfix for Microsoft Visual Studio 2010 Professional - ENU (KB2542054) KB2542054
This hotfix is for Microsoft Visual Studio 2010 Professional - ENU.
If you later install a more recent service pack, this hotfix will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/2542054.
Intel Visual Fortran Package ID: w_fcompxe_2011.7.258
Intel Visual Fortran Composer XE 2011 Update 7 Integration for Microsoft Visual Studio* 2010, 12.1.3518.2010, Copyright (C) 2002-2011 Intel Corporation
* Other names and brands may be claimed as the property of others.
Microsoft Visual Studio 2010 SharePoint Developer Tools 10.0.30319
Security Update for Microsoft Visual Studio 2010 Professional - ENU (KB2251489) KB2251489
This security update is for Microsoft Visual Studio 2010 Professional - ENU.
If you later install a more recent service pack, this security update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/2251489.
Wendy
One machine has VS 2010, 2008, and the Intel partner VS 2005 installed.
The other has only VS2010 installed, but has relics from VS 2008 (directories in Program Files).
Have read over the article in your recent post.
Only 4 dlls in the VFPackages folder: VFAVWin, VFHieEditor, VFProj, VFProjConvert.
The version of VFProj.dll looks correct.
Attached is the Help About from VS 2010.
C:\Program Files (x86)\Microsoft Visual Studio 10.0\Intel Fortran\VFPackages containing 4 dlls:
VFAVWin.dll
VFHieEditor.dll
VFProj.dll
VFProjConvert.dll
I may have stumbled on the solution though I do not have an explanation. It occurred to me to rename the solution file (project.sln) to something else (project.xxx) so that VS2010 would rebuild the solution file. I launched my project and did not get the error. I saved the new solution file. I launched and exited my project several times with no error. I then deleted the new solution and renamed my original solution back to project.sln. Again, I launched and exited several times with no error. So, at present, I cannot force the error to reoccur.
From Step 2 of the "Troubleshooting Fortran..." page that Wendy linked on the previous page of replies, I only have (the same as Glenn) 4 DLLs present:
VFAWin.dll
VFHieEditor.dll
VFProj.dll
VFProjConvert.dll
According to the linked page, I seem to be missing:
VFFortSvc.dll
VFToolOpt.dll
This was an upgrade from IVF 12 Update 4 to IVF12.1 Update 7.
The error popup I am getting suggests running devenv with /log and looking at a given file (Application Data\Microsoft\VisualStudio\10.0\ActivityLog.xml). I did that and the following entry stuck out to me:
I'll try Glenn's method and see if that fixes anything. Hopefully this information helps.
- Matt
Microsoft Office Developer Tools 01018-532-2002102-70812
Microsoft Visual Basic 2010 01018-532-2002102-70812
Microsoft Visual C# 2010 01018-532-2002102-70812
Microsoft Visual C++ 2010 01018-532-2002102-70812
Microsoft Visual F# 2010 01018-532-2002102-70812
Microsoft Visual Studio 2010 Team Explorer 01018-532-2002102-70812
Microsoft Visual Web Developer 2010 01018-532-2002102-70812
Wendy
Also, I noticed that after updating to Update 7 whenever I open my solution file (i.e. everytime), Visual Studio (devenv.exe) pegs my CPU out for about 2.5-3 minutes while it (VS) says it is parsing (what seems to be) every single file in each of the projects contained in my solution. Now, each of these projects share a number of files, yet the files are parsed multiple times as they are encountered in each and every project. Opening my solution under Update 4 never took more than about 30 seconds, and the CPU was never pegged out for more than one or two continuous seconds.
I went to try and use Glenn's suggestion, but since this particular solution contains 9 seperate projects it is not as simple as just deleteing the *.sln file and opening the .vfproj file. I was able to open all of the *.vfproj files individually as projects without error, but as soon as I went back to opening the main .sln file, I got the error once again.
I've included images of the error popup, and the only error in the ActivityLog.xml file for you to see.
Wendy
Wendy
I posted 3 Nov, regarding this error.
thanks
Wendy
I was not having this problem until I updated my VTune Amplifier XE to the update 6. Now I am getting the same error people have mentioned in this thread. Can I get the DLL fixes that you mentioned?
Jon
