I noticed a 'Hello World' at end of programming when debugging or exe on command line, but when used with redirect to file as in ftn_c.exe >ftn_c.txt, it appears before c function printf. (Or is this an OS(W10) "feature"?)
How do I make it wait for C function to return before proceeding?
!******************************** module ftn_C_2 interface integer (C_INT) function CPP_Library_Function & (sendbuf, sendcount, recvcounts) & BIND(C, name='CPP_Library_Function') use, intrinsic :: ISO_C_BINDING implicit none type (C_PTR), value :: sendbuf integer (C_INT), value :: sendcount type (C_PTR), value :: recvcounts end function CPP_Library_Function end interface end module ftn_C_2 ! ftn_c.f90 ! ! FUNCTIONS: ! ftn_c - Entry point of console application. ! !**************************************************************************** ! ! PROGRAM: ftn_c ! ! PURPOSE: Entry point for the console application. ! !******************************************** program ftn_c use, intrinsic :: ISO_C_BINDING, only: C_INT, C_FLOAT, C_LOC use ftn_C_2 implicit none ! Variables CHARACTER*1 CR CHARACTER*1 LF CHARACTER*1 NULL INTEGER :: CRET real (C_FLOAT), target :: send(100) integer (C_INT) :: sendcount integer (C_INT), ALLOCATABLE, target :: recvcounts(:) integer :: i CR=CHAR(13) LF = CHAR(10) NULL = CHAR(0) send(1)=1.0 do i=1,99 send(1+i)=2.0*send(i) end do ! ! Body of ftn_c ALLOCATE( recvcounts(100) ) ! sendcount = 100 CRET = CPP_Library_Function(C_LOC(send), sendcount, C_LOC(recvcounts)) ! print *, CR // LF //'Hello World' end program ftn_c
#include <cstdio> extern "C" int CPP_Library_Function(void* sendbuf, int sendcount, int *recvcounts) { for (int i = 0; i < sendcount; i++) { if (i > 0 && i % 4 == 0)printf("\n"); printf(" send(%02d)=%e ", i, *((float*)(sendbuf)+i)); } return 0x11; };
ftn_c.exe > ftn_c.txt:
Hello World
send(00)=1.000000e+00 send(01)=2.000000e+00 send(02)=4.000000e+00 send(03)=8.000000e+00
send(04)=1.600000e+01 send(05)=3.200000e+01 send(06)=6.400000e+01 send(07)=1.280000e+02
send(08)=2.560000e+02 send(09)=5.120000e+02 send(10)=1.024000e+03 send(11)=2.048000e+03
send(12)=4.096000e+03 send(13)=8.192000e+03 send(14)=1.638400e+04 send(15)=3.276800e+04
send(16)=6.553600e+04 send(17)=1.310720e+05 send(18)=2.621440e+05 send(19)=5.242880e+05
send(20)=1.048576e+06 send(21)=2.097152e+06 send(22)=4.194304e+06 send(23)=8.388608e+06
send(24)=1.677722e+07 send(25)=3.355443e+07 send(26)=6.710886e+07 send(27)=1.342177e+08
send(28)=2.684355e+08 send(29)=5.368709e+08 send(30)=1.073742e+09 send(31)=2.147484e+09
send(32)=4.294967e+09 send(33)=8.589935e+09 send(34)=1.717987e+10 send(35)=3.435974e+10
send(36)=6.871948e+10 send(37)=1.374390e+11 send(38)=2.748779e+11 send(39)=5.497558e+11
send(40)=1.099512e+12 send(41)=2.199023e+12 send(42)=4.398047e+12 send(43)=8.796093e+12
send(44)=1.759219e+13 send(45)=3.518437e+13 send(46)=7.036874e+13 send(47)=1.407375e+14
send(48)=2.814750e+14 send(49)=5.629500e+14 send(50)=1.125900e+15 send(51)=2.251800e+15
send(52)=4.503600e+15 send(53)=9.007199e+15 send(54)=1.801440e+16 send(55)=3.602880e+16
send(56)=7.205759e+16 send(57)=1.441152e+17 send(58)=2.882304e+17 send(59)=5.764608e+17
send(60)=1.152922e+18 send(61)=2.305843e+18 send(62)=4.611686e+18 send(63)=9.223372e+18
send(64)=1.844674e+19 send(65)=3.689349e+19 send(66)=7.378698e+19 send(67)=1.475740e+20
send(68)=2.951479e+20 send(69)=5.902958e+20 send(70)=1.180592e+21 send(71)=2.361183e+21
send(72)=4.722366e+21 send(73)=9.444733e+21 send(74)=1.888947e+22 send(75)=3.777893e+22
send(76)=7.555786e+22 send(77)=1.511157e+23 send(78)=3.022315e+23 send(79)=6.044629e+23
send(80)=1.208926e+24 send(81)=2.417852e+24 send(82)=4.835703e+24 send(83)=9.671407e+24
send(84)=1.934281e+25 send(85)=3.868563e+25 send(86)=7.737125e+25 send(87)=1.547425e+26
send(88)=3.094850e+26 send(89)=6.189700e+26 send(90)=1.237940e+27 send(91)=2.475880e+27
send(92)=4.951760e+27 send(93)=9.903520e+27 send(94)=1.980704e+28 send(95)=3.961408e+28
send(96)=7.922816e+28 send(97)=1.584563e+29 send(98)=3.169127e+29 send(99)=6.338253e+29 powershell
debug console stepping through code or exe at cmd or powershell:
PS C:\mw\c\vs2017\ftn_c\ftn_c\x64\Debug> .\ftn_c
Hello World
The issue is more than likely due to separate buffering of the output stream from the C++ function to the Fortran output. The function may have completed execution, but information written to the stream may be buffered and not be written to the physical device straight away, in the meantime the Fortran program writes its output, so you see an apparent ordering change. Buffering of streams is the sort of thing that changes when a language runtime figures out it is writing to a file rather than the console.
Try using the fflush C++ (and C) library function to flush stdout prior to returning to Fortran.
//fflush works. #include <cstdio> extern "C" int CPP_Library_Function(void* sendbuf, int sendcount, int *recvcounts) { for (int i = 0; i < sendcount; i++) { if (i > 0 && i % 4 == 0)printf("\n"); printf(" send(%02d)=%e ", i, *((float*)(sendbuf)+i)); } fflush(stdout); return 0x11; };
