I have just upgraded to latest version of Intel Fortran and am now getting a few of these warnings:
1>saq.f90
1>F:\src\saq\saq.f90: warning #6178: The return value of this FUNCTION has not been defined. [CP]
1>F:\src\saq\saq.f90: warning #6178: The return value of this FUNCTION has not been defined. [C_COPY]
There are no such variables CP or C_COPY in this file. Whilst they are just warnings, I would rather not have them. Any idea what is causing them and how to remove them?
<Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.6.0 Build 20220226_000000>
Those are the names of functions, not variables. It would help if you attached a copy of the source file named in the message (saq.f90). You can disable all warnings with /warn:nogeneral, but I would not recommend it.
Thanks Steve,
I can attach the file, however it is not compilable without a whole slew of modules. Here is a subset example of the file which still shows the problem:
subroutine saq_start_recording_internal(fpref,ierr)
use baq_sets_mod
character(*), intent(in ) :: fpref
integer , intent(out) :: ierr
character(:), allocatable :: fname, bit
character(8) :: date
character(10) :: time
integer ll
call date_and_time(date,time)
record = .true.
ll = len_trim(fpref)
if(fpref(ll:ll) == char(0)) ll = max(1,ll-1)
bit = '.'
if(fpref(ll:ll) == '/' .or. fpref(ll:ll) == '\') bit = ''
fname = fpref(1:ll) // bit // date // '.' // time // '.saq_record'
open(newunit=lun_record,file=fname, iostat=ierr)
call util_record_set_lun(lun_record)
call baq_internal_startrecording()
end subroutine
The use'd module baq_sets_mod contains c_copy here:
function baq_CopyFluid(c_orig) result(c_copy) bind(c, name= 'baq_CopyFluid' )
type(c_ptr), value, intent(in) :: c_orig ! original fluid
type(c_ptr ) :: c_copy ! copy fluid
type(t_bo_fluid), pointer :: f_orig, f_copy
call c_f_pointer(c_orig, f_orig)
allocate(f_copy)
f_copy = f_orig
c_copy = c_loc(f_copy)
if(record) call baq_record(22,1108,'baq_CopyFluid', fl=c_copy, fl_orig=c_orig)
end function
(cp is contained elsewhere in the file, but let me concentrate on c_copy for now)
Write back when you have a reproducible example we can look at. I tried massaging your snippet into something I could compile, got no warning.
