Warning:standard Fortran 95?
tnd
whenI compiler my fortran source(in fortran 90 format), the Intel fortran complier always says:
"Warning 4 : Tab characters are an extension to standard Fortran 95" .
I do not know what is going on ? would anyone like to help me?
many thanks.
ArturGuzik
Valued Contributor I
You havetabs in the source code (editor uses tabs instead of spaces - you can see it byclicking Togle WhiteSpace DisplayorpressingCtrl+Shift+8). Use Edit/Advanced/Untabify Selection to replace tabs with spaces in the code you have. To have spaces in the new files set Options/Tabs and select Insert spaces.
A.
tnd
Thank you for your help, according to what you said I have comeover the problem, thank again !
