29348 Discussions
What hath "TS 29113/TS 18508" wrought!?
FortranFan
The following simple code compiles fine with the latest Intel Fortran compiler 2015, update 2 but it gives an error with gfortran, a GCC 5.0 development trunk version.
The error, as shown below, has to do with "TS 29113/TS 18508", presumably related to further interoperability features with C in the next standard.   Now I am not sure if Intel has started implementing any of these features yet, so Intel Fortran compiler behavior may not be relevant yet.
However, looking at TS 29113, I don't see anything that states this code is in error; the code is so basic, if this is not allowed, then I wonder what is!  My take on this is gfortran has a bug; I would appreciate any comments and feedback on this.
module m
   use, intrinsic :: iso_c_binding, only : c_funptr, c_f_procpointer
   implicit none
   private
   abstract interface
      subroutine ifoo()
      end subroutine ifoo
   end interface
   type(c_funptr)           :: c_f_ptr
   procedure(ifoo), pointer :: f_f_ptr
contains
   subroutine set_fptr()
      call c_f_procpointer(c_f_ptr, f_f_ptr)
   end subroutine set_fptr
end module m
Compilation error with options -Wall -std=f2008 in gfortran :
m.f90:23.36:
                                    1
Error: TS 29113/TS 18508: Noninteroperable procedure pointer at (1) to C_F_PROCPOINTER
TimP
I don't see any such complaint from gfortran 5.0.0 20150326 (trunk as of 2 days ago).  The only complaint I see is about the tabs which appear when I copy and paste source from your post.
I ran the full test suite but apparently I no longer have privilege to post the results on the gcc site.  There are an inordinate number of failures associated with newer gfortran features on Windows, but it doesn't seem to impact usability.  ifort probably doesn't fare well either when running the gfortran test suite, but it's hard to do on account of the inconsistent options.
jimdempseyatthecove
FortranFan,
caviat: I haven't attempted your source above, nor use those interop features like you do in your source...
Reading the 15.0 referenc guide
C_F_PROCPOINTER
Intrinsic Module Subroutine: Associates a Fortran pointer of type INTEGER with the target of a C function pointer.
Module
USE, INTRINSIC :: ISO_C_BINDING
Syntax
CALL C_F_POINTER(cptr, fptr)
cptr
(Input) Is a scalar of derived type C_FUNPTR. Its value is the C address of a procedure that is interoperable.
fptr
(Output) Is a Fortran pointer of type INTEGER. It becomes pointer-associated with the target of cptr.
The above text leads me to believe the pointer must be to than of an INTEGER FUNCTION.
You are using it as a SUBROUTINE.
What happens if you change "subrouting ifoo()" to "integer function ifoo()"?
Jim Dempsey
Harald
You should have used "-std=f2008ts".
Harald
FortranFan
Jim,
Thanks for your comments, but I think that brings up another issue which is an inadequacy in some aspects of Intel Fortran compiler documentation.
The latest standard documentation shows the following:
FortranFan
I think I know what I did wrong: forgot to add BIND(C) attribute on the interface definition.  The code shown below compiles ok with gfortran.  But if that's the case, then I wonder if it really has anything to do with "TS 29113/TS 18508" and if the gfortran error shown the original post is misleading; but that's for GCC folks to think about.
And this brings up the question: should Intel Fortran raise an error/warning when BIND(C) is missing on the interface definition especially if -standard-semantics or -stand:f08 (or f03) is in effect?
module m
   implicit none
   private
   abstract interface
      subroutine ifoo() bind(c)  !.. BIND(C) added
      end subroutine ifoo
   end interface
contains
end module m
FortranFan
Tim Prince wrote:
I don't see any such complaint from gfortran 5.0.0 20150326 (trunk as of 2 days ago).  ..
Tim,
See Quote #4, perhaps you have "-stdf2008ts".  Otherwise, it's possible this aspect of C interoperability is in a flux in gfortran and compiler response may change from build to build due to code updates.
FortranFan
Harald
Good point, thanks for bringing this to my attention.
Intel Fortran never enforced the restrictions that arguments to routines in ISO_C_BINDING be interoperable. That requirement was lifted in TS29113, so Intel Fortran was "ahead of the curve" on that. Note that the restrictions were not in the form of constraints, so checking was not required. In F2008, the interoperable requirement (on the programmer) is still there.
The text in our documentation for C_F_PROCPOINTER referring to "type INTEGER" is an error. I will get that fixed. The fptr must be a procedure pointer.
JVanB
Valued Contributor II
Just for the sake of being totally OT, why didn't varargs procedures in interface bodies make it into the upgraded C interoperability? In MacOS, everything seems to go through a varargs function which is awkward to invoke currently. Seems like it would be more difficult for a Fortran compiler to document this than implement it.
The "interop TS" was almost entirely driven by MPI3. I don't recall any discussion of varargs and am uncertain how you would map that into a Fortran concept.
JVanB
If you are uncertain, then how does !DIR$ ATTRIBUTES VARYING work? Just plop that into the interface body for a procedure with the BIND attribute in some way acceptable to the standardization committee and it would be very helpful.
IanH
How would you write such a procedure in Fortran?
FortranFan
How does the following from TS 29113 help in this situation?
Further down in the appendix:
jimdempseyatthecove
FortranFan,
Can you append the C "fat binding" side to your example?
The general problem with "fat binding" is that the internal structure of the array descriptors is implementation dependent. For "portable" code, you will need (when using array descriptor or pointer to array slice) is for the Fortran caller to pass in to the C routine the reference (address) of the Fortran array descriptor/pointer. The C routine, will receive the Fortran array descriptor as an opaque object (note, for C++ the opaque object can have member functions, such as ()[]). The C routine can perform a callback function to the vendor's Fortran runtime library, or to a user Fortran subroutine, to obtain the pointer to the data and the ranks, sizes, stride, etc. IOW the vendor or user supplied routine will accept a vendor preferred array descriptor and return a (TBD) universal C friendly array descriptor/accessor.
Jim Dempsey
FortranFan
jimdempseyatthecove wrote:
FortranFan,
Jim,
Here's the link to TS 29113 if you're interested.
Shown below are the some additional details of the example and "fat binding" and use of optional arguments:
In response to RO's question, I was simply wondering if it is possible to make use of any of the TS 29113 enhancements in a way that can work with variable argument C procedures.
This doesn't match C varying arguments, which use a list-type structure. It also doesn't work well with the notion of an unlimited number of arguments since Fortran really doesn't have that concept (except with certain intrinsics such as MAX and MIN, which are not readily specifiable in an explicit interface.)
I suppose what could be done is add a VARYING attribute that must be on the last argument, specifying that there can be one or more of that type. I'm not sure how to work in argument name keywords, though.
JVanB
We seem to be on completely different planets, so I offer an example with !DIR$ ATTRIBUTES VARYING to make more clear my ideas.
module M
   use ISO_C_BINDING
   implicit none
   interface
      function wsprintf(lpOut,lpFmt)
         import
         implicit none
!DEC$ ATTRIBUTES C, alias: 'wsprintfA' :: wsprintf
!DIR$ ATTRIBUTES varying :: wsprintf
         integer(C_INT) wsprintf
         character(kind=C_CHAR), intent(out) :: lpOut(*)
         character(kind=C_CHAR), intent(in) :: lpFmt(*)
      end function wsprintf
   end interface
end module M
program P
   use M
   implicit none
   character(len=80,kind=C_CHAR) lpOut
   character(len=80,kind=C_CHAR) lpFmt
   character(len=80,kind=C_CHAR) mess
   integer(C_INT) variable
   integer(C_INT) R
   lpFmt = '%s = %d'//achar(10)//achar(0)
   mess = 'The variable'//achar(0)
   variable = 42
   R = wsprintf(lpOut,lpFmt,C_LOC(mess),variable)
   write(*,'(a)') lpOut(1:index(lpOut,achar(0))-1)
end program P
Output with ifort (64-bit Windows):
The variable = 42
Keywords aren't going to work and I'm not asking for callbacks. Why doesn't the above match C varying arguments?
FortranFan
We seem to be on completely different planets, ..
If one looks at this and this as well as the example from the appendix in TS 29113, it appears the general thinking is to employ C wrappers to get around situations that relate to any gaps in standard aspects of Fortran/C interoperability.  Is that too onerous for Mac OS APIs?
JVanB
Employing C wrappers was the f77 way. Since ifort already has the solution to the problem it seems surprising that there isn't a similar solution in the standard.
IanH
The facilities in the current standard are symmetric - an interoperable procedure can be written in either Fortran or C.  Variadic functions are not symmetric in this manner, with the Fortran language as it is now.  It might be only a philosophical barrier, but I think that a sufficient reason for the absence of interoperability with variadic functions.  You would at least want to have a concept of how they could be done in Fortran worked out, before you specified the Fortran to C interoperable case, just so you didn't make things more difficult for later language evolution.
We are a lot better off today than we were with Fortran 77.
