What statements cause a beep?
Intel_C_Intel
I have some legacy code and sometimes on user input a beep occurs.
This can be annoying for others so I'm trying to remove all beep calls.
The only one I can find is :-
lret=MessageBeep(MB_ICONSTOP)
There must be others as some beeps still occur.
Any suggestions, thanks,
David
Intel_C_Intel
David,
my guess is a Beep function, that is, Beep (dwFreq, dwDuration)) (boolean type, arguments of type dword)
or BeepQQ run-time subroutine (within DFLib). Latter takes frequency and duration as parameters of type Integer 4.
Artur
david_jones
Writing ascii character 7 (BEL) to a console, as in :
write(*,*) char(7)
will cause a beep.
David Jones
isn-removed200637
It might be worth going to the Windows Start..settings..Control Panel..Sounds and Multimedia
to see what windows messages have had sounds associated with them (e.g. message boxes with MB_iconexclamation etc)
Try setting all the sounds to 'none' and seeing what happens.
Steven_L_Intel1
Another thing that can cause a beep is if you press a key while Windows isn't looking for a keypress. This won't happen in a Console application, but could (I think) happen in a QuickWin and definitely in a Windows application.
Steve
Intel_C_Intel
Thanks for all your suggestions, but none of these seem to cause the beep.
David
gfthomas8
You say that is happens 'sometimes' This suggests to me that the input is being masked for valid keystrokes; if it passes, no beep, and converesly. Windows supplies the beep for free if warranted (well it does so in VC++ and VB so you might want to see if it does likewise in VF).
