29649 Discussions
When I use block and derived data type at same time, some errors occurred. This may be a bug?
wang1
This is the code, the correct code is
module Test
implicit none
type :: s
    integer,allocatable,dimension(:)::x
end type s
end module Test
program main
use Test
implicit none
type(s),allocatable::a(:)
type(s)::b
integer::i
i=2
if (== 1) then
    block
        !allocate (a(3))
    end block
else
    block
        allocate (a(5))
        do i = 15
            a(i)%x=[i]
        end do
        b = a(2)
        write (**)
    end block
end if
end program main
 and we get that the b%x is a array with size 1, and value is 2. As the figure show
But if we uncomment the allocate (a(3)) statement, we get
the b%x is Undefined address, but the allocate (a(3)) statement should not run , and doesn't affect the result of b. So I dont't know if it's a bug of ifort.
Labels (2)
Steve_Lionel
Yes, it's a bug. With the first allocate commented out, the compiler is deallocating array a at the end of the second block, which it should do only if it was declared within that block (it wasn't). With the first allocate uncommented, the compiler doesn't do the bad deallocate.
Steve_Lionel
