In order to access the member variables of a derived data returned by a function, do I have to assign it to a local variable or I can use it directly.
For example,
function A returns B, which has a member variable called C
Can I write it in A()%C?
Or I must go
type(b) :: D
D=A()
D%C
For example,
Or I must go
type(b) :: D
D=A()
D%C
The latter. There is no available syntax in Fortran to reference components of a function result.
Note that you can do the following:
call examine_result( f(....) )
subroutine examine_result( r )
type(some_type) :: r
a = r%a
end subroutine
This is especially useful if the result of the function is an array whose length depends on the data you feed the function:
call examine_result( pack( values, values > 0.0 ) )
Arjen
Thanks, Steve.
Just wonder why.
It's because this causes bad performance or memory management issue or bad coding style or something else?
As you know, in object-orinted derived data type, this feature makes coding very easily. Otherwise, lots of local variables must be declared.
Just wonder why.
The language standards committee did once consider such a thing, but it didn't make it into the standard.
To expand on Arjen's comment, consider the following:
Jim Dempsey
[fortran]! compile with preprocessor enabled
module mod_foo type obj real :: a,b,c end type obj type(obj), target :: x,y,z contains ! function to return pointer to persistant object function foofoo(pick) type(obj), pointer :: foofoo integer :: pick nullify(foofoo) if(pick == 1) foofoo => x if(pick == 2) foofoo => y if(pick == 3) foofoo => z end function foofoo ! functions to return referenct to member variables real function fooA(afoo) type(obj) :: afoo fooA = afoo%a end function fooA real function fooB(bfoo) type(obj) :: bfoo fooB = bfoo%b end function fooB real function fooC(cfoo) type(obj) :: cfoo fooC = cfoo%c end function fooC end module mod_foo ! *** do not place the #define in mod_foo, place in source using mod_foo
! *** #define is global to remainder of source file ! *** n is object index (pick) ! *** m is member variable name #define foo(n,m) foo##m(foofoo(n)) program fnptr use mod_foo x%a = 1.0 x%b = 2.0 x%c = 3.0 y%a = 4.0 y%b = 5.0 y%c = 6.0 z%a = 7.0 z%b = 8.0 z%c = 9.0 ! the following will not work ! write(*,*) foofoo(2)%b ! The following works write(*,*) fooB(foofoo(2)) ! The following is equivilent to the above write(*,*) foo(2,B) end program fnptr [/fortran]
Jim Dempsey
