I bought Visual Fortran Compiler 10.0.25. When I install it, automaticaly it installs visual studio 2005. The problem is when i make a project. I write the code in a f90 file (this file is inserted in a fortran project) and when i want to compile it i don't find the compile button.
As mentioned in the release notes, there are a few features not available when you use the bundled Visual Studio 2005 Premier Partner Edition, and one of these is the ability to compile a single source. Typically one builds the solution or project rather than do a file by file compile.
Version 10.1.021 is the current version.
