Hallo,
Compaq Fortran 6.6 Professional Edition
We are running CAD system Medusa NG 2003_200 which contains an interface to fortran programs and offers access to the so called DARS-Library.
To compile the programs the following is required:
Compaq Fortran 6.6 Professional Edition.
We are aware that this version isn't up to date but all efforts with other compilers (Intel Visual Fortran Compiler 8.0 and 9.1 Standard Edition) have failed. Furthermore the supplier of Medusa specifies expressly the use of this Fortran Version (additional requirements: MS-Visual Studio 6.0, respektively MS C++ 6.0).
We have been trying to find a vendor for this Fortran Compiler but have not suceeded. Would you be able to help?
Are you able to supply Compiler Compaq Fortran 6.6 Professional Edition?
If not, could you suggest someone who might be able to do so?
Our operation system is XP service pack 2
Thank you for your help.
Kind regards, Rudolf
I have and use 6.6c Pro, but am not selling! As far as I know, Compaq Visual Fortran(CVF) is no longer marketed and, more importantly, no longer supported (although I am quite happy with it).
You would be wise to post here what exactly 'fails' when you try and compile your code using the Intel Fortran compiler, as this is the best place to get knowledgeablehelp.There are people here who can work out most problems, sojust jump in with your problems.
