29413 Discussions
Why can not we use some win32 api in fortran windows application?
lm_lxt
Why can not weuse some win32 api in fortran windows application?
In fact,there are many win32 api which works well in c++ but can not be used in fortran windows application !
Paul_Curtis
Valued Contributor I
There's no such thing as "can not use". If an INTERFACE to an API function is missing from the IVF resources (ie, IFWINTY, etc), then you may have to write it yourself, but this becomes quite straightforward once you have done it a few times, and of course the (thousands of) existing INTERFACES serve as an explicit guide. What particular Win32 functions can you not access?
