29376 Discussions
Why /heap-arrays0 cause /qopenmp show access violation for do concurrent?
CRquantum
A very simple question about do concurrent. Code is below,
program mainomp
  implicit none
  integer, parameter :: r8=selected_real_kind(15,9)
  real, allocatable :: x(:,:,:),ks(:,:,:),xs(:,:,:)
  integer :: i,j,nstep,np,nd,l,k
  real(kind=r8), parameter :: as(4,4) = reshape([ &
    &  0.0_r8,              0.0_r8,              0.0_r8,              0.0_r8, &
    &  2.71644396264860_r8, 0.0_r8,              0.0_r8,              0.0_r8, &
    & -6.95653259006152_r8, 0.78313689457981_r8, 0.0_r8,              0.0_r8, &
    &  0.0_r8,              0.48257353309214_r8, 0.26171080165848_r8, 0.0_r8 ], [4,4])
  np=10**5
  nd=2
  nstep=10**3
  allocate(x(np,nd,0:nstep))
  allocate(xs(np,nd,4))
  allocate(ks(np,nd,4))
  do k = 1, nstep
    do j = 1,4
      do concurrent (l=1:nd)
        xs(:,l,j) = x(:,l,k-1) + matmul(ks(:,l,:j-1),as(:j-1,j))
      enddo
    enddo
  enddo
end program mainomp
The problem is, if I compile with /qopenmp and with /heap-arrays0 as below,
When I run code I got error message 'access violation',
forrtl: severe (157 Program Exception - access violation
Image              PC                Routine            Line        Source
openMPtest.exe     00007FF6CC756A0A  Unknown               Unknown  Unknown
openMPtest.exe     00007FF6CC7317B2  MAIN__                     20  main_omp.f90
libiomp5md.dll     00007FF80756D853  Unknown               Unknown  Unknown
libiomp5md.dll     00007FF8074CEC67  Unknown               Unknown  Unknown
libiomp5md.dll     00007FF8074D0A26  Unknown               Unknown  Unknown
libiomp5md.dll     00007FF807487751  Unknown               Unknown  Unknown
openMPtest.exe     00007FF6CC73155C  MAIN__                     19  main_omp.f90
openMPtest.exe     00007FF6CC761E5E  Unknown               Unknown  Unknown
openMPtest.exe     00007FF6CC76223C  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FF8A9EC7034  Unknown               Unknown  Unknown
ntdll.dll          00007FF8AABA2651  Unknown               Unknown  Unknown
at line
However, without heap-arrays as below, the code with -qopenmp works, no error.
Can someone please explain why heap-arrays will cause /qopenmp and do concurrent not compatible? Thanks much in advance!
I use Intel OneAPI 2022.0.3 on Windows 10 21H2.
PS.
A similar post is here below,
https://fortran-lang.discourse.group/t/why-heap-arrays0-cause-qopenmp-show-access-violation-for-do-concurrent/3122
Ron_Green
Hi @CRquantum
I saw this issue on fortran-discourse this morning.  I ran a few tests.  This bug appears on all 3 supported OSes.  What's more, the OMP equivalent:
  do k = 1, nstep
    do j = 1,4
      !$omp parallel do
      do l=1,nd
      enddo
    enddo
  enddo
has no problem.  I even tried the LOCAL_INIT clause but that was no help.
It's interesting, it crashes on the first entry to DO CONCURRENT.  Here's my hack to test when the fault occurs:
  do k = 1, nstep
    do j = 1,4
      print*, "calling do concurrent k and j are: ", k,j
      print*, "nd is ", nd
      enddo
    enddo
  enddo
  print*, "done"
./a.out
 calling do concurrent k and j are:            1           1
 nd is            2
forrtl: severe (174): SIGSEGV, segmentation fault occurred
So definitely an interaction of HEAP-ARRAYS.  Bug ID is CMPLRIL0-34679.  Barbara will track this bug for us.  Thanks for bringing this issue to our attention
ron
CRquantum
Thank you Ron! Well our first names are kind of similar, mine is Rong yours is Ron, LOL.
Yes, right now, it seems if I have to use heap-arrays + -qopenmp, then I have to change all the ```do concurrent``` just to regular ```do``` and add ```!$OMP PARALLEL DO``` as you did.
Hopefully this bug could be fixed soon. After all, it is really cool if -qopenmp can be compatible with heap-arrays and do concurrent.
Rong
Barbara_P_Intel
This issue with DO CONCURRENT and HEAP-ARRAYS is fixed in the latest Fortran compiler, ifx 2022.2.0, available in oneAPI 2022.3. Please try it.
CRquantum
