29641 Discussions
Why the parallelization does not work?
xu_jocelyn
With IVF Compiler 10.1, A same program performs on IA32 architecture (Intel Pentium D CPU/ Ms Windows XP Home Edition) and Intel 64 architecture (Dual-Core AMD Opteron Processor 2214 / Ms Windows Server 2003 Enterprise x64 Edition SP2) respectively. Both projects are optimized with '/O3 /Og /QaxN /QxN /Qparallel' etc. Few loops in program main are auto-parallelized or vectorized.
Then, I add some '!DEC$ PARALLEL' directives before the appropriate loops, however, no otherinformation of 'auto-parallelized' appears, and the running efficiency does not improved in fact. Why the directive does not work?
Moreover, the dual-core or quad-core processors above seem not work, while the auto-parallelized program runs almost with only single core. Could the auto-parallelization fully use all cores of CPU? Or my settings have any mistakes? What is the best setting about above two systems?
Thanks!
I'd suggest that you make use of the optimization reports to see what the compiler thought of your loops.
By the way, there's no point in saying both /QxN and /QaxN. I suggest /QxW /QaxP.
If you're seriously interested in making use of the multiple cores, I recommend looking at OpenMP rather than auto-parallel.
