Why value of local array is saved between function calls?
S__MPay
I noticed if I define a local variable in a function:
realdimension(n1, n2) :: myArray
myArray will keep its last values next time I call function causing wrong calculations.
Before I assumed dimension keyword will allocate and initialize an array with zero members.
How can I prevent this and reset the array. I think using myArray(:, :) = 0. is not efficient.
Andrew_Smith
New Contributor III
Arrays and scalars are not initialized to zero by default. It is not standard Fortran to do so but you can set a compiler flag to make it happen.
Explicit setting to zero is better practice and will be efficiently done by the compiler, no less so than a zero setting to zero by compiler flag.
There is a useful compiler setting to set signalling nan to these floating point types and it would help you detect any more cases where you assumed zero.
Andrew_Smith
New Contributor III
Arjen_Markus
Honored Contributor I
Note that instead of:
myArray(:,:) = 0
you can also use:
myArray = 0
mecej4
A local variable, strictly speaking, is undefined whenever the subprogram is entered, unless it has the SAVE attribute. It is the programmer's responsibility to do any desired initialization.
There is no compiler option to zero a variable each time the subprogram is entered. You can request the zeroing to be done when the program starts. The variable will then be zero only when the subprogram is entered the first time. Even then, the values of unsaved local variables will be undefined for subsequent entries to the same subprogram. They may retain the values from the previous entry, by coincidence, or the values may be trash values that were placed in the same memory locations in another subprogram.
TimP
Ifort gives local arrays a default SAVE attribute.  This is among the reasons for recommending decorating procedures which should be thread safe with RECURSIVE.  Compile flag -Qauto and others which imply it have the same effect.
As mentioned above, if you want the array zeroed each time you should assign 0 explicitly.  Ifort normally would generate efficient code for this, likely with a memset function call.
Steve_Lionel
Some additional comments...
- /Qauto or similar will replace the "remembered values" with random values from whatever was on the stack. The arrays will not be reset to zero.
- The compiler option to zero-initialize variables happens before the program starts - it does not reset values on each procedure call.
Explicit code to zero-initialize the arrays is the only correct way of solving this issue.
S__MPay
Here I will post a summary of all the answers:
Andrew Smith wrote:
Arrays and scalars are not initialized to zero by default. It is not standard Fortran to do so[...]
Explicit setting to zero is better practice and will be efficiently done by the compiler [...]
mecej4 wrote:
There is no compiler option to zero a variable each time the subprogram is entered. [...]
myArray(:,:) = 0
you can also use:
myArray = 0
