Window Closing Event?
reneeculver
I know what it is.... I don't know it's syntax for a console process.
Renee
Jugoslav_Dujic
Valued Contributor II
SetConsoleCtrlHandler + write your own HandlerRoutine.
reneeculver
Well that was adequately confusing. I'm using Ifort and you gave me an MS routine. How do the two relate?
I can see where it would be nice but it has to be called by ifort unless there is a way to call it and I just haven't run into it yet.
Renee
onkelhotte
New Contributor II
You can use Win32 Methods with IVF.
Just "use ifwin" and you can call them.
Markus
reneeculver
Well then thank youi!!! I bet "use" is C?
Renee
jimdempseyatthecove
Renee,
"use" is more analogous to C++'s
"#include PreCompiledHeader" combined with Link of .obj file containing code+data (if any)of precompiled header
Jim Dempsey
reneeculver
Can someone give me an example of a window-closing event?
Renee
reneeculver
I have been researching this and will it also be useable on 64 Bit software?
Also how does someone let ifort know that win32 software is to be called?
Renee
