Windows API (SHFileOperation)
lou-muccioli
I'm getting a crash when I call SHFileOperation and I suspect it may have something to do with the sh.pFrom structure member which is defined as INTEGER (LPCSTR) in INFWINTY.F90. Any help would be greatly appreciated.
Program DelDirRecursive
USE IFPORT
USE IFWIN
implicit none
character*256 cString
integer ierr, kerr
TYPE (T_SHFILEOPSTRUCT) sh
cString = ' '
sh.hwnd = NULL
sh.wFunc = FO_DELETE
sh.pFrom = 'ABC'C
sh.pTo = NULL
sh.fFlags = FOF_SILENT
sh.fAnyOperationsAborted = NULL
sh.hNameMappings = 0
sh.lpszProgressTitle = NULL
ierr = SHFileOperation (sh)
if (ierr .ne. 0) print *,' I/O Error'
if (ierr .eq. 0) print *,' Success'
stop
end
Robert_van_Amerongen
New Contributor III
Dear Lou, I read your problem and read the SDK for the SHFILEOPSTRUCT structure. There I found that both the members pFrom and pTo must be double NULL-terminated. See the explicit warning at: http://msdn.microsoft.com/en-us/library/windows/desktop/bb759795(v=vs.85).aspx Maybe this helps? Robert
lou-muccioli
Hi Robert, Yes, I seen that as well but can't seem to nail down the correct syntax to make it double null terminated. Lou
IanH
To append two nulls to a string you could do something like: [fortran] string_with_two_nulls = 'abc' // achar(0) // achar(0) [/fortran] The ISO_C_BINDING intrinsic module provides the C_NULL_CHAR constant that is more or less equivalent to ACHAR(0).
lou-muccioli
This seems to do the trick. Now, the "real" program passes in the directory name as "fdir(1:leng)" and I'm having trouble getting that to work but I'll keep debugging. Program DelDir USE IFPORT USE IFWIN implicit none character*256 cString integer ierr, kerr TYPE (T_SHFILEOPSTRUCT) sh character(512) :: file_spec = "ABC"C//""C ! double null terminator sh.hwnd = NULL sh.wFunc = FO_DELETE sh.pFrom = loc (file_spec) ! Added this sh.pTo = NULL sh.fAnyOperationsAborted = NULL sh.fFlags = FOF_NOCONFIRMATION sh.hNameMappings = 0 sh.lpszProgressTitle = NULL ierr = SHFileOperation (sh) if (ierr .ne. 0) kerr=-1 if (ierr .eq. 0) kerr=0 stop end
