Hi all,
I have struggled setting the DYLD_LIBRARY_PATH in OS X El Capitan with the las install of ifort in command line only.
There seem to be a mistake in the installation directories : "/opt/intel//" instead of "/opt/intel/". This error was found in compilevars.sh as well as in mklvars.sh.
Vincent
Hi Vincent. Sorry to hear about the struggle. Just to confirm that I'm reading your post correctly. Did you find this with our most recent PSXE 2016 Update 2 release for OS X?
Hi Kevin, I used the online installer. ifort --version just gave me :
ifort (IFORT) 16.0.2 20160204
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
Regards, Vincent
Thank you. That is our latest Update 2. I'll look into this and update after I know more.
I reproduced/confirmed the extraneous slash in the PROD_DIR setting is a defect and escalated the matter to our developers. Thank you for reporting this.
(Internal tracking id: DPD200411070)
