29640 Discussions
Wrong source code information in idb
lorenzen
I have trouble with the ifort v9.1.036 Fortran compiler and the idb debugger. The source files are preprocessed by the GNU C preprocessor that inserts line number directives. When compiling the source with the -g switch and examining a backtrace in idb all line number information is wrong. I also tried preprocessing with the Intel fpp but that did not help either. Is there some pitfall with that combination? Any help is very much appreciated as debugging with wrong source code locations is almost useless.
Florian
I'd suggest that you report the problem to Intel Premier Support and attach a test case.
