Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
XE2017 with 15.0
Hello:
Sorry if this question has already been asked, or covered somewhere, but I'm not finding the information offhand.  I have Windows 10, Visual Studio 2015, and the XE 2017 (17.0) compiler.  I would like to also install (side-by-side) the 15.0 (update 4) version of the compiler.  Is that possible?  I have the w_fcompxe_2015.4.221.exe file, but that installation file seems to just hang, and then bomb out, with no specific error messages.
So I'm first wondering if it's possible to have the 2 versions installed together.  And, if so, I'm wondering how to do it, given that I already have 17.0 installed and working.
Michael
Highlighted
Black Belt Retired Employee
From the FAQ:
Steve (aka "Doctor Fortran") - https://stevelionel.com/drfortran
Highlighted
Yes, thank you.  Sorry, I should have mentioned that I did come across that page.  That does seem to indicate that I should be able to have 17.0 and 15.0 running side-by-side.  Correct?  (I may be missing something in my interpretation of what I'm reading on that page).  But I'm still not sure why the installation didn't work right.
Perhaps the part I missed is about deleting the "Intel Fortan" subfolder.  I'll look at that more carefully.
Michael
Highlighted
I would not expect the install to fail, but if you can't work it out, uninstall both versions, delete the Intel Fortran folder, and then install 15 first, then 17.
