Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Xilink.exe stops working error
Building my project in VS2015 Update 1 using PSXE2015 update 6 it crashes with the windows error boxes. What do I do when I get this?  It doesn't give any sort of diagnostic so it isn't clear.  I can't send in the project. Nothing in the build log other than PRJ0019
Dave
Highlighted
What compiler options are you
What compiler options are you using? Is this only one project or is anything doing it? If you are not using /Qipo a workaround is to replace xilink.exe in the Fortran bin\ia32 or bin\intel64 folder with link.exe from VS2015's VC\bin or VC\bin\amd64 folder.
Retired 12/31/2016
Highlighted
Here is the command line
Here is the command line generated:  We set /Qnoipo  I'll try the replacement.
 /OUT:"x64\Debug\astap_16.dll" /VERBOSE /INCREMENTAL:NO /NOLOGO /LIBPATH:"..\DLLs_x64" /MANIFEST /MANIFESTFILE:"x64\Debug\astap_16.dll.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"C:\sf60.git\astap\x64\Debug\astap_16.pdb" /MAP /SUBSYSTEM:WINDOWS /STACK:1200000000 /IMPLIB:"C:\sf60.git\astap\x64\Debug\astap_16.lib" /DLL /qnoipo  "..\TempWorkspace16\x64\procesvs10_16\Debug\procesvs10_16.lib" "..\ProcessModulesDll\x64\Debug\ProcessModulesDll_16.lib" "..\x64\Debug\ProcessorCGlobals_16.lib" ""..\TempWorkspace16\x64\utilityCur_16\Debug\utilityCur_16.lib"  "tdsubproc.lib" "statwin.lib" "sfmatlab.lib" "LVCompartment.lib" "SaveSetWriter.lib" "multicalc16.lib" "..\SamgDll\samgDll\x64\Debug\SamgDll_16.lib" /section:.data,RWS "x64\Debug\astap.obj" "C:\sf60.git\TempWorkspace16\x64\procesvs10_16\Debug\procesvs10_16.lib" "C:\sf60.git\ProcessModulesDll\x64\Debug\ProcessModulesDll_16.lib" "C:\sf60.git\TempWorkspace16\x64\utilityCur_16\Debug\utilityCur_16.lib" "C:\sf60.git\SamgDll\SamgDll\x64\Debug\SamgDll_16.lib"
Creating command line "Link @"C:\sf60.git\astap\x64\Debug\RSP1.rsp""
astap_16 : error PRJ0019: A tool returned an error code
astap_16 - 1 error(s), 0 warning(s)
Highlighted
Replacing with link.exe gives
Replacing with link.exe gives the strange error:
1>------ Build started: Project: astap_16, Configuration: Debug x64 ------
1>Linking...
1>LINK : warning LNK4044: unrecognized option '/qnoipo'; ignored
1>Starting pass 1
1>LINK : fatal error LNK1181: cannot open input file '.obj'
Is there a line length limit that is causing it to truncate the input?
Highlighted
/Qnoipo is not a supported
/Qnoipo is not a supported option and certainly the Microsoft linker doesn't know it. The proper spelling of that on Windows would be /Qipo- but that's the default. It's ok to have the linker ignore that.
The real problem seems to be that "x64\[]" - where did that [] come from? That should be the name of an object file. You may want to check your project settings. Can you upload a ZIP of the .vfproj file? I don't need to see the sources.
Retired 12/31/2016
Highlighted
Well I only checked a box in
Well I only checked a box in VS for no IPO.  Are the flags it chooses to output under my control?  The VS form says /qnoipo in the comments.
I don't see a [] in my text, or on the screen or anywhere.  Attaching the .vfproj file.
Thanks for looking.
Highlighted
Nevermind.  a "" at the
Nevermind.  a "" at the beginning of a file name.  Not that I think the linker should crash on that, but it was my typo.
