Dear all,
I wrote an example for getting in touch with assumed rank arrays and got two issues. Once an ICE assumed in subroutine bar in line 44 (if un-commented) and in foo in line 22 a run-time error is thrown for i>=2. To get the ICE one have to uncomment lines 21 to 23. The ICE occures in PSXE 2016.3 up to version 2017.2.
Maybe the things I do are not standard conform...
module mod_subs implicit none contains subroutine foo(t) implicit none real, intent(inout) :: t(..) integer :: i integer :: i_rank integer, allocatable :: i_size_1(:), i_size_2(:) i_rank = rank(t) allocate(i_size_1(i_rank)) allocate(i_size_2(i_rank)) i_size_1=shape(t) write(*,'("The rank of the array is: ",*(i3))') i_rank ! gives 3 write(*,'("The shape of the array is: ",*(i3))') i_size_1 ! gives 2 2 2 write(*,'("The content of the array is: ",*(f6.2))') t ! stops at 2.0 do i = 1, i_rank i_size_2(i) = size(t,dim=i) ! runtime error at i=2: The DIM value 2 must not be greater than 1, the rank of array 'T'. end do return end subroutine foo ! -------------------------------------------- subroutine bar(t) implicit none real, intent(inout) :: t(..) integer :: i integer :: i_rank integer, allocatable :: i_size(:) i_rank = rank(t) allocate(i_size(i_rank)) i_size=shape(t) write(*,'("The rank of the array is: ",*(i3))') i_rank ! gives 3 write(*,'("The shape of the array is: ",*(i3))') i_size ! gives 2 2 2 write(*,'("The content of the array is: ",*(f6.2))') t ! stops at 2.0 !write(*,*) t(1:i_size(1),1:i_size(2),1:i_size(3)) ! un-commenting throws an ICE (PSXE 2016.3 up to 2017.2) return end subroutine bar end module mod_subs program Assumed_Rank use mod_subs implicit none ! Variables integer :: i, j, k real, dimension(2,2,2) :: r_dummy ! Body of Assumed_Rank r_dummy = reshape([1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0],[2,2,2]) do i = 1, size(r_dummy,dim=3) do j = 1, size(r_dummy,dim=2) do k = 1, size(r_dummy,dim=1) write(*,'(*(f6.2))',advance='no') r_dummy(k,j,i) end do write(*,'(/)') end do end do call foo(r_dummy) call bar(r_dummy) end program Assumed_Rank
Compiling with Intel(R) Visual Fortran Compiler 17.0.2.187 [Intel(R) 64]... ifort /nologo /debug:full /Od /warn:interfaces /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc140.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin\amd64" /Qm64 "D:\02_Fortran\99_test\Assumed_Rank\mod_subs.f90" ifort /nologo /debug:full /Od /warn:interfaces /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc140.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin\amd64" /Qm64 "D:\02_Fortran\99_test\Assumed_Rank\Assumed_Rank.f90" Linking... Link /OUT:"x64\Debug\Assumed_Rank.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"x64\Debug\Assumed_Rank.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\02_Fortran\99_test\Assumed_Rank\x64\Debug\Assumed_Rank.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"D:\02_Fortran\99_test\Assumed_Rank\x64\Debug\Assumed_Rank.lib" -qm64 "x64\Debug\mod_subs.obj" "x64\Debug\Assumed_Rank.obj" Embedding manifest... mt.exe /nologo /outputresource:"D:\02_Fortran\99_test\Assumed_Rank\x64\Debug\Assumed_Rank.exe;#1" /manifest "x64\Debug\Assumed_Rank.exe.intermediate.manifest" Assumed_Rank - 0 error(s), 0 warning(s)
1>------ Rebuild All started: Project: Assumed_Rank, Configuration: Debug x64 ------ 1>Deleting intermediate files and output files for project 'Assumed_Rank', configuration 'Debug|x64'. 1>Compiling with Intel(R) Visual Fortran Compiler 17.0.2.187 [Intel(R) 64]... 1>mod_subs.f90 1>fortcom: Fatal: There has been an internal compiler error (C0000005). 1>compilation aborted for D:\02_Fortran\99_test\Assumed_Rank\mod_subs.f90 (code 1) 1>Assumed_Rank.f90 1> 1>Build log written to "file://D:\02_Fortran\99_test\Assumed_Rank\x64\Debug\BuildLog.htm" 1>Assumed_Rank - 1 error(s), 0 warning(s) ========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
I can reproduce both of these. Thank you. I'll roll these up to Development shortly.
Hi Kevin,
thanks fro the quick reply. The simpler version with just using a fix index below produces also the ICE.
Anyway, does the standard allow the use of assumed rank in such a way? What is meant by the help exactly:
An assumed-rank variable name must not appear in a designator or expression except as one of the following: - An actual argument corresponding to a dummy argument that is assumed-rank - The argument of the C_LOC function in the ISO_C_BINDING intrinsic module - The first argument in a reference to an intrinsic inquiry function
subroutine bar(t) implicit none real, intent(inout) :: t(..) integer :: i, j, k integer :: i_rank integer, allocatable :: i_size(:) i_rank = rank(t) allocate(i_size(i_rank)) i_size=shape(t) write(*,'("The rank of the array is: ",*(i3))') i_rank ! gives 3 write(*,'("The shape of the array is: ",*(i3))') i_size ! gives 2 2 2 write(*,'("The content of the array is: ",*(f6.2))') t ! stops at 2.0 write(*,'(*(f6.2))',advance='no') t(1,1,1) ! also an ICE return end subroutine bar
This version works. Line 20 of original foo should throw a compile time error IMHO...
subroutine foo(t) use, intrinsic :: iso_c_binding, only : c_loc, c_ptr, c_f_pointer implicit none real, intent(inout) :: t(..) integer :: i integer :: i_rank integer, allocatable :: i_size_1(:), i_size_2(:) real, pointer :: pt_t(:,:,:) i_rank = rank(t) allocate(i_size_1(i_rank)) allocate(i_size_2(i_rank)) i_size_1=shape(t) write(*,'("The rank of the array is: ",*(i3))') i_rank ! gives 3 write(*,'("The shape of the array is: ",*(i3))') i_size_1 ! gives 2 2 2 !write(*,'("The content of the array is: ",*(f6.2))') t ! stops at 2.0, error expected !do i = 1, i_rank ! i_size_2(i) = size(t,dim=i) ! runtime error at i=2: The DIM value 2 must not be greater than 1, the rank of array 'T'. !end do call c_f_pointer( cptr=c_loc(t), fptr=pt_t, shape=i_size_1 ) write(*,'("The content of the array is: ",*(f6.2))') pt_t ! prints 1.0 to 8.0 return end subroutine foo
I reported the issues to Development. Yes, for the case that compiles/runs, the usage appears non-conformant; therefore, should provoke a compile-time error I believe. Thank for the additional concise test cases.
(Internal tracking id: DPD200418864 – internal error with assumed-rank array)
(Internal tracking id: DPD200418868 – missing error for non-conformant assumed-rank array usage)
