bug in ifort?
MR
not sure this is the right place, however
I would like to report what seems to me a bug
in ifort.
The attached code works when compiled with
ifort ib.f90 -o ib
but does not when compiled with
ifort ib.f90 -r8 -o ib
My compiler:
ifort -V
Intel Fortran Compiler for Intel EM64T-based applications, Version 9.1 Build 20061101 Package ID:
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
Thanks, Best Regards
Marco Restelli
The "right place" is Intel Premier Support.
You don't say how it doesn't work. I'm going to guess that you're seeing a segv or stack overflow based on my trying the application though I don't understand why the compiler is creating a stack temp here. I'll look into that.
If that is the problem, raise your stack limit (ulimit -s) or compile with -heap-arrays.
MR
Steve,
thank you.
Indeed, the error was:
./ib
A
Segmentation fault
and raising the stack limit or compiling with -heap-arrays
solves the problem.
Best Regards
Marco Restelli
