29641 Discussions
call Fortran subroutine using only static library (.lib) without dll?
Soniya
is that possible to call Fortran subroutine using only static library (.lib) without dll?
garraleta_fortran
Yes
a)Create Library
b)Use Library
Steve_Lionel
It's possible that what Soniya has is a DLL export library, which is also a .lib but is not a static library. If that's what one has, the corresponding DLL is required to run the linked program, as the .lib contains no code, just information about the DLL.
garraleta_fortran
Let sonya clearly explain what she wants to do
