call system help
roddur
in a old program, i have to run the executable together .let they are A,B and C
EXECUTABLE A and B
cd
../a.out (see, the executable is one step up in directory tree)
and for C
cd
./c.out
now, instead of running all the executable seperatly, i tried something like:
call system ('cd && ../a.out &')
in C main file.
expecting the job will run on background and transfer the control outside the call statement....but this is NOT what i am getting.
can anybody help me?
TimP
Are you supplying a "system" subroutine of your own? If so, did you supply an INTERFACE or put it in a MODULE? A real example would be needed to see if there is a bug here.
If you mean to use the one provided by ifort, it looks like you omitted "USE ifport," as you should have got compiler complaints about CALLing a function. Yes, it's incompatible with gfortran and g77. Remind me never to use this stuff without the following style:
#ifdef _INTEL_COMPILER
USE ifport
#endif
icode = system("yourscript")
#elif defined(__GNUC__)
call system('yourscript')
#else
error "system call in unknown compiler environment"
#endif
Choosing cpp style, as that is mandated by OpenMP, thus supported by more compilers than other pre-processing styles.
Note that systemqq is equivalent, but has a logical rather than integer return type.
Simple command lines are OK if they will work in a new copy of the same shell you used to start the program. You could also start a script which specifies which shell it runs. Backgrounding the script won't necessarily work the same in Windows, in case that interests you.
According to the gfortran documentation, its implementation of SYSTEM is as either a subroutine or a function (but only one at a time can be used in a program unit.) As best as I can tell, Intel Fortran behaves the same way, but if you USE IFPORT, then you must use it as a function. For portability, as best as one can be portable with a non-standard routine, it's probably best to use it as a function.
In any event, I don't think that the form of the call is the issue here. To the best of my knowledge, SYSTEM will execute one command only, not a series of commands. Perhaps if you wrote a shell script you could invoke it with a call to SYSTEM.
TimP
That's interesting; I have used the function call form with apparent success with gfortran, then I read another copy of gfortran documentation which said only the subroutine was supported.
Anyway, it seemsmore reliableto write a script which specifies the shell, even when issuing a pair of commands.
The OP also asked this in comp.lang.fortran, where a script was also recommended.
