In my application, Fortran code must be compiled on the customer's computer. But the code is distributed as an encrypted file. The installation program will decrypt the Fortran code prior to compilation. With g95, it is possible to send the code
to the compiler using a pipeline: "decrypt sourcefile | g95 - "
Is there any way that ifort can be instructed to read from standard input so that a pipeline can be used?
Alternately, can ifort's input file sourcefile.f90 be in some way encrypted or hidden so that the customer cannot capture it?
Quoting - ajboeckmannyahoo.com
currently, no, this capability is not provided.
I am investigating how gcc/g++ and gfortran provide this capability, as we might wish to stay compatible. perhaps a feature request will come from this. I will post once I've completed my research.
ron
Quoting - Ronald Green (Intel)
ron
Ronald, notice that g95 is a diferent project from gfortran. Check
http://www.g95.org/
(it's also open source but diferent)
Quoting - rreis
http://www.g95.org/
my mistake, I was aware of the difference but I must have skimmed over the original post too quickly (late afternoon eyes and brain).
maybe you can write a program to compile your program? it would be a binary installer which would decrypt the files to a tmp dir, compile and clean? you could use call System to use available tools in the OS. of course you would have a temporary dir that could be captured but that wouldn't be obvious. I don't know how you're installer works, is it binary? What stops the costumer from intercepting the pipeline? Can't the sensitive parts of the code be compiled as a library?
well, these are just some thoughts...
ron
I entered Feature Request DPD200137322 for this.
Features such as this typically appear in major versions, if at all. They have to be prioritized with all other features for future products. Thus, it could take anywhere from a year or more to 3 years (if it is accepted at all). I just wanted to set your expectations, I would not expect this to appear in a product in the near term. Thus, you should pursue another solution if you have immediate needs.
Thank you for sending this to us. I agree it is a good request and would make a good addition to the compiler.
ron
Quoting - Ronald W. Green (Intel)
Thank you for doing this. It is too late for us right now , but may be useful in the future.
ron
