can't get VERF function to work
Ahmad_Falahatpisheh
Hi All,
I am trying to use verf in my fortran 90 code. I have followed both the procedures for both IMSL and MKL. I set the library and include directories in Visual Studio and I still can't build my code in VS. The famous error shows up:
error LNK2019: unresolved external symbol _VERF referenced in function _MAIN__
The code is in the following form:
program test
include "mkl_vml.f90"
call verf(1,a,y)
end program
Then I tried the following to build it:
ifort myfortran.f90 %LINK_FNL_HPC%
but I got the following error:
ifort: command line warning #10161: unrecognized source type '%LINK_FNL_HPC%'; object file assumed
Could someone shed light on this problem?
mecej4
The routine name is probably vserf or vderf; these are among the vectorized error functions in MKL.
Unless your code calls IMSL routines, you do not need IMSL. The compiler did not find LINK_FNL_HPC defined in the environment where you ran it. That is one of the variables that is set up by the IMSL batch file, fnlsetup.bat.
Ahmad_Falahatpisheh
I am not writing a code which is optimized for parallel processing. I wanted to calculate error function in a regular way. Is there other library or I have to write my own code to calculate that function?
Thanks a lot.
mecej4
In that case, just call the intrinsic function ERF(). For just that, you need neither MKL nor IMSL.
I cannot find a routine named VERF in either MKL or IMSL. Have you purchased and installed IMSL?
Ahmad_Falahatpisheh
Yes I purchased and installed Intel Visual Fortran v11.1 + MKL for Win, Aca, ESD. The MKL directory contains:
  • benchmarks
  • bin
  • examples
  • include
  • interfaces
  • lib
  • tests
  • tools
I have a fortran 90 handbook but it does not mention anything about ERFC function. I just found online that ERFC is an intrinsic Fortran function. Do you know any comprehensive Fortran 90 handbook?
ERFC is a Fortran 2008 function and is supported by version 11.1. You can find its description in the Intel compiler Language Reference.
Ahmad_Falahatpisheh
Thanks Steve. Does Intel has the PDF version of it?
Sorry, no PDF version. You can read it online here.
mecej4
ERFC(x) = 1 - ERF(x)
Do not use one for the other!
Arjen_Markus
That is as far as the mathematical definition is concerned. The raison d'etre for erfc() in F2008
is (at leastthat is how I understand it)that for large arguments computing the one from the other
is very problematic - the error function rapidly approaches 1 and then the above computation is numerically
inaccurate.
Arjen
