29298 Discussions
cannot run idb in parallel model on Linux x86
kiscky
Hello there,
I've been struggling for quite a bit now to try and use the debugging tool 'idb' in parallel mode. I would like to use it to debug my Fortran 90 program compiled with ifort (single process) and with mpif90 (multi-processes).
I succesfully managed to debug a single-threaded program. In order to run idb in parallel mode I followed the instructions in the manual ( http://scv.bu.edu/computation/linuxcluster/docs/intel_comp_docs_7.1/docs/idb_debugger_manual.htm#at.para , at "Starting a Parallel Debugging Session" ) but this is what I get when I launch my program caled "les3d-mp" :
[up0002.hpcvl.org:07605] procdir: /tmp/openmpi-sessions-hpc2133@up0002.hpcvl.org_0/37008/0/0
[up0002.hpcvl.org:07605] jobdir: /tmp/openmpi-sessions-hpc2133@up0002.hpcvl.org_0/37008/0
[up0002.hpcvl.org:07605] top: openmpi-sessions-hpc2133@up0002.hpcvl.org_0
[up0002.hpcvl.org:07605] tmp: /tmp
[up0002.hpcvl.org:07605] [[37008,0],0] node[0].name up0002 daemon 0 arch ffc91200
mpirun was unable to launch the specified application as it could not find an executable:
Executable: -b
Node: up0002.hpcvl.org
while attempting to start process rank 0.
[up0002.hpcvl.org:07605] sess_dir_finalize: job session dir not empty - leaving
[up0002.hpcvl.org:07605] sess_dir_finalize: proc session dir not empty - leaving
orterun: exiting with status -123
when I execute the command:
mpirun -dbg=idb -np 2 les3d-mp
I would really appreciate your help,
Carlo
Aubrey_W_
I'm moving this thread to the Intel Fortran Compiler for Linux and Mac OS* X forum so that the Intel Software Development Products team can assist you.
Aubrey W.
Intel Software Network Support
kiscky
Thank you Aubrey!
