catastrophic error: ICE
eliosh
For some reason I get a catastrofic error when I try to compile one of the attached files:
ifort ice.f90
gives me the following
0_12032
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for ice.f90 (code 3)
--------------------------------------------------------------------------------------------------------------------------------~/sandbox/fortran/opt$ ifort -V
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100203 Package ID: l_cprof_p_11.1.069
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
For your convenience I attach all three files (the main program and two modules).
Thank you.
Ron_Green
I'll get a bug report started. Thanks for sending this to us.
issue ID is DPD200151591
ron
Ron_Green
This was fixed in the 13.1 compilers
ron
