catastrophic error
William_Sailor
------ Build started: Project: QWinSPE, Configuration: Release|x64 ------
Compiling with Intel Visual Fortran 11.1.035 [Intel 64]...
main_spe_sim.for
0_1984
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
in file D:\FTN\MYN\src\main_spe_sim.for, line 1, column 15
compilation aborted for D:\FTN\MYN\src\main_spe_sim.for (code 3)
Build log written to "file://D:\FTN\MYN\lib\QWinSPE\x64\Release\BuildLog.htm"
QWinSPE - 1 error(s), 0 warning(s)
---------------------- Done ----------------------
Thanks - I can reproduce it. If you turn off the floating point stack check, it will compile - this option should be meaningless on x64 anyway... Issue ID is DPD200139531.
Please attach the source file that triggered this so that we can get it fixed - thanks.
William_Sailor
Hope this works
Please also attach the include files it needs and the compile command used (you can get that from the build log.)
William_Sailor
Steve here is the buildlog, and the includes are attached.
Build Log
Output
ifort /nologo /I&quotD:FTNMYNinclude" /extend_source:132 /warn:declarations /warn:unused /warn:interfaces /assume:minus0 /Qfp-stack-check /module:&quotx64Release\" /object:&quotx64Release\" /check:all /libs:qwin /c /extend_source:132 /Qvc8 /Qlocation,link,&quotC:Program Files (x86)Microsoft Visual Studio 8VCbinamd64" &quotD:FTNMYNsrcmain_spe_sim.for"
0_1984
in file D:FTNMYNsrcmain_spe_sim.for, line 1, column 15
compilation aborted for D:FTNMYNsrcmain_spe_sim.for (code 3)
William_Sailor
Steve,
Thanks that does it
Bill
