Community
cancel
Showing results for
Search instead for
Did you mean:
-check-all issue
Jump to solution
Dear all,
when compiled with "-check all", the following simple code fails at compile time or run time depending on which line is commented:
      program test
      implicit none
      real    :: kpt(3,64)
      integer :: i,n
      n = 9
      kpt(:,n:) = kpt(:,[(i,i=64,n,-1)]) ! fails at run time
c      kpt(:,9:) = kpt(:,[(i,i=64,9,-1)]) ! fails at compile time
      end
Compile with:
ifort -check all test.f
Error message during compile time:
test.f(7): error #5581: Shape mismatch: The extent of dimension 1 of array KPT is 3 and the corresponding extent of array <RHS expression> is 56
Error message during run time:
forrtl: severe (408): fort: (33): Shape mismatch: The extent of dimension 1 of array KPT is 3 and the corresponding extent of array <RHS expression> is 56
In my opinion, the error messages are incorrect. The dimension 1 of the RHS is also 3. The dimension 2 is 56 (on both sides).
ifort --version
ifort (IFORT) 19.0.3.199 20190206
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
Thank you.
Best
Christoph
Accepted Solutions
Highlighted
Valued Contributor I
Yes, indeed, this seems to be
Jump to solution
Yes, indeed, this seems to be a problem with ifort, confirmed. Array bounds checking works with gfortran, NAG, and PGI.
ifort v18 also works, probably a regression.
Highlighted
Valued Contributor III
At first glance, it does look
Jump to solution
At first glance, it does look like a bug in Intel Fortran compiler with -check:all option - I suggest submitting a support request.
Highlighted
Jump to solution
Highlighted
Thank you. I will do that.
Jump to solution
(They should have a link here to the bug report page or, even better, a button to directly file a bug report.)
Highlighted
Black Belt Retired Employee
(No subject)
Jump to solution
Steve (aka "Doctor Fortran") - https://stevelionel.com/drfortran
