check for infinity
tropfen
is there a way to check for the value Infinity? (like ISNAN)
I do know it would be better to avoid Infinity before it comes. But what i need is a check for.
If there is no good way by now, is it possible to add a function into IVF to do this? The value Infinity must have in some way a spezific look like.
Thanks in advance
Frank
TimP
IEEE_IS_FINITE and IEEE_IS_NAN are documented for the current release. They were supported before appearing in the documentation.
Wang_J_
How to use 'IEEE_IS_FINITE '?  When  i directly use it like 'if(variable==IEEE_IS_FINITE ) then', it does not work well. Even 'variable' is infinity, the progam do not go into the if  .
Les_Neilson
Valued Contributor II
You will need something like :
    use, intrinsic :: ieee_arithmetic
    logical result
    result = ieee_is_finite(variable)
and test  if (.not.result) then     ! variable is not finite
or
    if (.not. ieee_is_finite(variable)) then
    endif
Les
