coarray
Rodrigues__Pedro
  Hello
     I tried a simple 'hello' coarray and at runtime I got this:
        unknown option: -localonly
    what those this means?
             thanks in advance
Please show the command line session including the compile command used and all its output. If you did this in Visual Studio, attach a ZIP of the buildlog.htm from the Debug or Release folder.
Lorri_M_Intel
I'm going to guess that you have a full version of MPI installed on your system, and that it's not the Intel MPI.
When the coarray program starts up, it invokes mpiexec.exe with the command line option "-localonly".   The other mpiexec.exe is probably on your PATH ahead of the one we supplied on the Intel Fortran kit, found in Common Files\Intel\Shared Libraries\redist\<arch>\mpirt\
                --Lorri
Rodrigues__Pedro
 Hello
    I am a sending the zip file.
thanks
Lorri's answer is better than mine.
Rodrigues__Pedro
   No doubt. I had my path with with ms MPI ahead. Problem solved.
   thanks
