WARNING: If the code below does not compile immediately, please Ctrl-C fast; otherwise, huge cores are being produced, and you may have to restart your workstation.
! Code from Figure 19.3 on page 324 of "Fortran 95/2003 explained" ! IFORT 15.0.1 compiles the code, and the program runs fine. ! IFORT 16.0.0 never returns from compilation; Ctrl-C causes ! huge core files to be created Module list_module Implicit None Type node Integer :: value = 0 Class(node), Pointer :: next_node => Null() Contains Procedure :: pwf Generic :: Write(Formatted) => pwf End Type node Contains Recursive Subroutine pwf(dtv, unit, iotype, vlist, iostat, iomsg) Class(node), Intent(In) :: dtv Integer, Intent(In) :: unit Character(*), Intent(In) :: iotype Integer, Intent(In) :: vlist(:) Integer, Intent(Out) :: iostat Character(*), Intent(InOut) :: iomsg Character(10) :: pfmt Write(unit, fmt = '(i9,/)', iostat = iostat) dtv%value If(iostat /= 0) return If(Associated(dtv%next_node)) Write(unit, fmt='(dt)', iostat=iostat) dtv%next_node End Subroutine pwf End Module list_module Program test Use list_module Implicit None Type(node), Target :: first_link = node(42, Null()) Type(node), Target :: second_link = node(43, Null()) Type(node), Target :: third_link = node(44, Null()) first_link%next_node => second_link second_link%next_node => third_link Print '(dt)', first_link End Program test
Thanks - I can reproduce this and escalated as issue DPD200381365. The key seems to be the component that is a pointer to its own type - if that is removed, it compiles. I suspect that the compiler is now trying to chase down the tree when it shouldn't, but I'll wait to see what the developers say.
Indeed, this is a bug that snuck in while we were redoing some code. I expect it to be fixed in Update 3.
