compilervars.sh failure
Vaughn
Actually, it's not the compiler.  I'm just upgrading my Fortran compiler to the 2020 upgrade 1 on my Linux machine and the install.sh did its thing successfully, but I can't seem to get compilervars.sh to run to completion. All I see is:
bash: /opt/intel/compilers_and_libraries_2020/linux/bin/compilervars.sh: line 115: syntax error near unexpected token `('
bash: /opt/intel/bin/compilervars.sh: line 115: ` local arr=(`echo ${!arg} | sed 's/:/\n/g'`)'
What am I doing wrong?
  -- Vaughn
Ron_Green
you are sourcing it, and passing it's required argument of 'intel64' or 'ia32'?
source <path>/compilervars.sh intel64
Vaughn
Yes, my command line reads compilervars.sh intel64.  I'm sorry I did not say that explicitly.
  -- Vaughn
mecej4
Running the script directly accomplishes nothing. You have to use the command (replace "<path>" by the path for your installation)
source <path>compilervars.sh
 Without "source" followed by a space added as a prefix, the script will run and terminate, and the environment that it sets up will be in effect only while the script is running. The "source"+space prefix is needed to have the environment persist in the shell that you are running even after the script terminates.
Vaughn
what I meant was my cmd line was
$ source /opt/intel/bin/compilervars.sh intel64
