complex*32 and real*16
paolodenti
SUBROUTINE LUCINQP(AM,NDDMST,N,IER)
DIMENSION AM(40,40),V(40)
COMPLEX*32 AM
REAL*16 V
REAL*16 SUM
DO 1309 I=1,N
SUM=0.0Q0
DO 1319 J=1,N
1319 SUM=SUM+REAL(AM(I,J))**2+IMAG(AM(I,J))**2
1309 V(I)=1.0Q0/SUM
return
end
gives the message
t.f(1): warning #18000: The specified alignment (32) cannot be honored. Instead an alignment of 16 is used
Instead,
dimension a(1000,1000),b(1000)
complex*32 a
real*16 b
do 1 i=1,1000
b(i)=0.0q0
do 1 j=1,1000
1 a(i,j)=(0.0q0,0.0q0)
b(611)=qacos(0.0q0)*2
a(27,311)=(1.0q0,-2.0q0)*.5q0
write(11,*)sqrt(a(27,311))
write(11,*)b(611)
stop
end
returns no message and works fairly in q-precision.
Steven_L_Intel1
This is a bug that is fixed in version 11.
TimP
Quoting - paolodenti
COMPLEX*32 AM
REAL*16 V
REAL*16 SUM
DO 1309 I=1,N
SUM=0.0Q0
DO 1319 J=1,N
1309 V(I)=1.0Q0/SUM
return
end
gives the message
I don't get any message with ifort 11 beta Intel64. You must have used a different compiler; how is anyone to guess? Are you implying that it didn't work? By the way, you are lucky if non-standard quad precision in the style of 20 years ago is working for you. In particular, use of REAL this way could be ambiguous.
Steven_L_Intel1
