complining error
msaadatpour
Dear Admin
I am using the trial version of intel visul fortran 11.01.65 in my research
programming. When I am debugging the program, some time there have been
10 error, some times 7 errors, and at the end "Fatal: There has been an
internal compiler error (C0000005)." without changing the programming
code (debug mode). I want to know why this problem would be occure?
Attached please find the whole of my project?
M. Saadatpour
Ph. D Candidate of Environmental & Water Resources Engineering
Iran University of Science and Technology
Aubrey_W_
I'll move this thread tothe Intel Fortran Compiler forum, so one of our technical consulting engineers can answer it.
Aubrey W.
Intel Software Network Support
Dear M. Saadatpour,
An "internal compiler error" is almost always a compiler bug. For some reason I cannot download your attachment. Would you please upload it again and attach it to a new reply? We apologize for the inconvenience.
I was able to locate your attachment.
I can confirm that this fails to compile in all 11.1 versions, but it builds in 12.0 Update 2 (Intel Visual Fortran Composer 2011 Update 2.) However, the compiler also detects some coding errors. In the call to DENSITY at line 30 in hydroinout.f90, the first two arguments passed are of type REAL(8), but the corresponding dummy arguments in DENSITY are REAL(4). This will cause incorrect results and must be fixed.
