Hi, my IT department recently rebuilt my computer with a Windows 8 OS and an installation of Intel Composer XE 2015 and Visual Studio 2013. I opened a command window using the icon labeled "Intel 64 Visual Studio 2013 mode," changed directories so that I was in "C:\Program Files (x86)\Intel\Composer XE 2015\mkl\bin", and ran the following line: "mklvars intel64 mod ". I then changed directories again to a location where I keep some scripts, and ran a makefile that used to work with Composer 15. However, this installation doesn't seem to be able to find MKL, because I got the following errors:
Wal83.f(5): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MKL95_LAPACK]
USE mkl95_LAPACK, ONLY: GEEV
Wal83.f(241): error #6406: Conflicting attributes or multiple declaration of name. [GEEV]
CALL GEEV(TestMat,WR,WI,INFO=INFO)
I checked all of the paths in the makefile, and I can't find anything wrong with them. Can anyone please help me with this? I will reprint the makefile below. Thank you!!!
LINCL=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\include
LINCL_95=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\include\intel64\lp64
L1=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\intel64\mkl_intel_lp64.lib
L2=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\intel64\mkl_intel_thread.lib
L3=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\intel64\mkl_core.lib
L4=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\intel64\mkl_sequential.lib
L5=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\intel64\mkl_blas95_lp64.lib
L6=C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\intel64\mkl_lapack95_lp64.lib
all:
ifort /Qopenmp /I"$(LINCL)" /I"$(LINCL_95)" Wal83.f Wmod83.f ModApril2013.f \
"$(L1)" "$(L2)" "$(L3)" "$(L4)" "$(L5)" "$(L6)"
cls:
del -f *.obj *.exe *.log
The names of the MKL Fortran 95 modules were changed some months ago. Look in the .../mkl/include/intel64/lp64 directory for module files containing "95" in their names. You probably need to have "USE lapack95" in your program.
Thank you!!-that worked.
