29429 Discussions
custom INT to handle rounding errors of operations
Leos_P_
Problem of INT() is that it is not necessarily predictable in the sense e.g. INT(5.D0/1.D0) is not necessarily 5 but cal also happen to be 4. NINT() does not really help as NINT(4.8) = 5. In other words, I would need exact arithmetics. So I tried to write a simple function:
FUNCTION f_int(x) RESULT(i_x)
REAL(KIND=8) x, DEPS
INTEGER i_x
PARAMETER ( DEPS = 5.D-15 )
IF ( ABS( NINT(x) - x ) .GT. DEPS) THEN
	i_x = INT(x)
ELSE
	i_x = INT(NINT(x))
ENF IF
END FUNCTION f_int
My question is, does this make sense for the purpose I need and what can I be missing (while I realise that if I wanted to do things like e.g. 5.99999999978/1.999999999999999 on purpose, it would probably fail but I can live with this)?
jimdempseyatthecove
Incorrect, the above will produce 5.
However note, INT(SomeEpressionWithErrorThatMathematicallyShouldResultIn5.0D0 / 1.0D0) may not necessarily be 5.
Sketch of questionable code
ValueWithError = 0.1D0 ! infinitely repeating fraction (IOW contains error in LSB)
Result = DoubleFunctionThatProduces~5.0D0using(ValueWithError)
I_X = INT(Result / 1.0D0) ! not necessarily 5.
Consider  using:
nBitsPrecision = ... ! you specify here
if(Result .NE. 0.0D0) Result = Result + (NEAREST(Result,Result) * (2.0D0**nBitsPrecision))
I_X = INT(Result)
You can also use EPSILON to similar effect.
Jim Dempsey
mecej4
My question is, does this make sense for the purpose...
You have not yet declared what your purpose is.
Not available with machine floating point.
FortranFan
@Leos P.,
It would appear you're looking for the ANINT standard intrinsic function in Fortran: https://software.intel.com/en-us/node/679004
If not, you would need to furnish more details.
