29376 Discussions
derived-type IO with larger arrays (error)
Ferdinand_T_
New Contributor II
Dear All,
with the unformatted IO of (larger) arrays throgh user-defined derived-type transfer stamenets, I get the following error (upon reading the array back):
        forrtl: severe (67): input statement requires too much data
The error appears at different points in a larger transfer (including nested child transfer statements), depending on the sizes of the data. I managed to reproduce the error with the followign code on ifort 14.0.3:
[fortran]
module m
    implicit none
     ! global IO data
     ! critical size: 4 * 2**15 bytes (131.07200 kB)
    integer, parameter :: ARR_SIZE = 2**15    ! = 32768; no crash with 2**15 - 1
    integer, dimension(ARR_SIZE) :: arr        ! crash with/without dynamic allocation
    ! writing data through user-defined dt-transfer
    type :: t
        logical :: non_empty
    contains
        ! unformatted read/write
        procedure :: read_unformatted
        procedure :: write_unformatted
        generic :: read(unformatted) => read_unformatted
        generic :: write(unformatted) => write_unformatted
    end type
contains
    subroutine read_unformatted(this, unit, iostat, iomsg)
        implicit none
        class(t), intent(inout) :: this
        integer, intent(in) :: unit
        integer, intent(out) :: iostat
        character(len=*), intent(inout) :: iomsg
        ! read data, crash
        ! forrtl: severe (67): input statement requires too much data, unit -130
        read(unit, iostat=iostat, iomsg=iomsg)  arr
    end subroutine
    subroutine write_unformatted(this, unit, iostat, iomsg)
        implicit none
        class(t), intent(in) :: this
        ! write data
        write(unit, iostat=iostat, iomsg=iomsg) arr
    end subroutine
end module
program p
    use m    ! load data and type(t) IO-transfer statements
    implicit none
    type(t) :: my_t
    ! I/O
    integer :: unit
    integer :: iostat
    character(len=999) :: iomsg
    ! write ---------
    open( &
        newunit = unit, &
        action = 'write', &
        file = 'io.dat', &
        form = 'unformatted', &
        iostat = iostat, &
        iomsg = iomsg &
    if (iostat /= 0) then
        stop 'error opening file for writing'
    end if
    ! I. write data
        print *, 'iomsg = ', iomsg
        stop 'error writing to file (I)'
    end if
    ! II. write same data through dt-transfer
    write(unit, iostat=iostat, iomsg=iomsg) my_t
        stop 'error writing to file (II)'
    end if
    close(unit)
    ! read ----------
    open( &
        newunit = unit, &
        action = 'read', &
        file = 'io.dat', &
        iostat = iostat, &
        iomsg = iomsg &
        stop 'error opening file for reading'
    end if
    ! I. read data
        stop 'error reading from file (I)'
    end if
    ! II. read data through dt-transfer - crash
    read(unit, iostat=iostat, iomsg=iomsg) my_t
        stop 'error reading from file (II)'
    end if
    close(unit)
end program
[/fortran]
  • No error: Reading and writing the array 'arr' with a classical IO-statement (I) works fine, even reading back with the dt-transfer (II) is ok.
  • Only when writing with dt-transfer (II), there is no way (neither (I) nor (II)) reading back the array without error.
  • No error: for arrays smaller than a critical size of 4 * 2**15 bytes
  • No error  if the read/write statement transfers multiple variables (e.g. as in read(unit) A,B,...) with total size (A+B+...) >= the critical size, but individual sizes (A, B, ..). smaller.
Compile-line and output:
$ ifort test.f90 && ./a.out
 iomsg =
 input statement requires too much data, unit -130, file /home/s_ftschi/Desktop/
 test/io.dat
Any suggestions on how to avoid the error are very welcome!
(preferably on a higher level, since the error appears in variuos deeply nested transfer statements)
Best regards
Ferdinand
Ferdinand_T_
New Contributor II
Corrected formatting: [fortran]
module m
    implicit none
    ! global IO data
    type :: t
    contains
    end type
contains
        implicit none
        ! read data, crash
    end subroutine
        implicit none
        ! write data
    end subroutine
end module
program p
    implicit none
    type(t) :: my_t
    ! I/O
    integer :: unit
    integer :: iostat
    ! write ---------
    open( &
        newunit = unit, &
        action = 'write', &
        file = 'io.dat', &
        iostat = iostat, &
        iomsg = iomsg &
    end if
    ! I. write data
    end if
    end if
    close(unit)
    ! read ----------
    open( &
        newunit = unit, &
        action = 'read', &
        file = 'io.dat', &
        iostat = iostat, &
        iomsg = iomsg &
    end if
    ! I. read data
    end if
    end if
    close(unit)
end program
[/fortran]
I can reproduce the problem. The error is actually with the DTIO Write, where it is writing the file with an invalid record length in the header and trailer of the record. I will do a bit more analysis and then pass it on to the developers. Issue ID is DPD200363176.
jimdempseyatthecove
Steve,
FWIW in this case, the size(userDerivedType) does not represent the size of the data to be written, which is an array in a module, not in the type. Perhaps the buffer allocation looks at larger of "current buffer" or "size(userDerivedType)", and adjusts the buffer size in the case of the latter, and in either case the resulting buffer would be smaller that the data written.
Jim Dempsey
There's no requirement that the size of the data in the I/O statement match the amount of data the DTIO routine writes. This is simply a bug in our DTIO support.
The bug has been fixed - I expect the fix to appear in Update 2, planned for February. The fix is in the run-time library, so if you linked to the DLL libraries (the default nowadays) you won't have to recompile.
