In the fortran, how to detect "NaN", "....", "???" apearing for a real variable and to stop the running of the code immediately after detecting it?
If you want to test in code for a NaN, use the intrinsic function ISNAN. (This is an extension - a future version will support the F2003 standard routine for this purpose.)
If you want the program to stop automatically when a NaN is seen, then change the Floating Point Exception behavior to /fpe:0.
