29651 Discussions
dfwin message box not displayed in debug build
David_Mccabe
the following code only seems to produce a winapi message box when built in release mode:
[FORTRAN]
program test
 use dfwin
 integer :: button
 integer :: hOwner
 button = Messagebox(hOwner,"press ok..."//char(0),"test"//char(0),MB_OK)
end program test
[/FORTRAN]
Is there anyway to output a message box in debug mode?
dboggs
You didn't say what kind of project you're building, but with "use dfwin" I presume it is a Quickwin app. In this case you can use MESSAGEBOXQQ which you may find slightly easier to use and better behaved. btw, you should now use IFQWIN instead of the older DFWIN. You can also simplify the null-terminated strings, e.g. 'test'C is equivalent to 'test'//char(0)
IanH
The variable hOwner is undefined when you call MessageBox. Define it to be something meaningful - 0 perhaps.
David_Mccabe
Thank you both. Messagebox is displayed after setting hOwner to 0. I will use IFQWIN from now on.
