The do-concurrent construct is supposed to replace forall, but in this test it takes double the time to complete the same job if the indices is well ordered and gives a very slow time if not:
PROGRAM TEST_DO_SPEED IMPLICIT NONE REAL, ALLOCATABLE :: A(:,:,:), B(:,:,:), C(:,:,:) REAL :: TIC INTEGER :: T0, T1, T2, T3, T4, T5, T6 INTEGER :: I, J, K INTEGER, PARAMETER :: L = 1024, M = 512, N = 512 ALLOCATE( A(L,M,N), B(L,M,N), C(L,M,N) ) CALL RANDOM_NUMBER(A) CALL RANDOM_NUMBER(B) CALL RANDOM_NUMBER(C) CALL SYSTEM_CLOCK( T0, TIC) DO CONCURRENT( K=1:N, J=1:M, I=1:L) C(I,J,K) = A(I,J,K) +B(I,J,K) END DO CALL SYSTEM_CLOCK(T1) DO CONCURRENT( I=1:L, J=1:M, K=1:N) C(I,J,K) = A(I,J,K) +B(I,J,K) END DO CALL SYSTEM_CLOCK(T2) DO K=1,N DO J=1,M DO I=1,L C(I,J,K) = A(I,J,K) +B(I,J,K) END DO END DO END DO CALL SYSTEM_CLOCK(T3) C = A + B CALL SYSTEM_CLOCK(T4) FORALL(K=1:N, J=1:M, I=1:L) C(I,J,K) = A(I,J,K) + B(I,J,K) END FORALL CALL SYSTEM_CLOCK(T5) FORALL(I=1:L, J=1:M, K=1:N) C(I,J,K) = A(I,J,K) + B(I,J,K) END FORALL CALL SYSTEM_CLOCK(T6) PRINT*,"DO CONCURRENT 1 : ",(T1-T0)/TIC PRINT*,"DO CONCURRENT 2 : ",(T2-T1)/TIC PRINT*," ORDINARY DO : ",(T3-T2)/TIC PRINT*," ARRAY DO : ",(T4-T3)/TIC PRINT*," FORALL 1 : ",(T5-T4)/TIC PRINT*," FORALL 2 : ",(T6-T5)/TIC END PROGRAM
It gives:
DO CONCURRENT 1 : 0.3280000
DO CONCURRENT 2 : 2.250000
ORDINARY DO : 2.891000
ARRAY DO : 0.2810000
FORALL 1 : 0.2810000
FORALL 2 : 0.2820000
Edit : Sorry,I was wrong. after adding the line 'CALL RANDOM_NUMBER(C)' the time of has changed.
Read https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/499840
For fun a did a variation of your code with 6 'runs' and took the average time. They area ll the same except "Do concurrent 2" where the optimiser clearly must make some poor choices. Having said that with such a simple test the optimiser might make some decisions to "simplify" the code in some of the cases anyway.
DO CONCURRENT 1 : .08117
DO CONCURRENT 2 : 1.87650
ORDINARY DO : .07917
ARRAY DO : .08033
FORALL 1 : .08033
FORALL 2 : .08067
! do_conc_test.f90 ! PROGRAM TEST_DO_SPEED IMPLICIT NONE REAL, ALLOCATABLE :: A(:,:,:), B(:,:,:), C(:,:,:) REAL :: TIC, t_all(6) INTEGER :: t(0:6) INTEGER :: I, J, K, NT !INTEGER, PARAMETER :: L = 1024, M = 512, N = 512 INTEGER, PARAMETER :: L = 1024, M = 256, N = 256 integer, parameter :: N_tries = 6 ALLOCATE( A(L,M,N), B(L,M,N), C(L,M,N) ) CALL RANDOM_NUMBER(A) CALL RANDOM_NUMBER(B) CALL RANDOM_NUMBER(C) t_all = 0.0 do NT = 1 , N_tries CALL SYSTEM_CLOCK( T(0), TIC) DO CONCURRENT( K=1:N, J=1:M, I=1:L) C(I,J,K) = A(I,J,K) +B(I,J,K) END DO CALL SYSTEM_CLOCK(T(1)) DO CONCURRENT( I=1:L, J=1:M, K=1:N) C(I,J,K) = A(I,J,K) +B(I,J,K) END DO CALL SYSTEM_CLOCK(T(2)) DO K=1,N DO J=1,M DO I=1,L C(I,J,K) = A(I,J,K) +B(I,J,K) END DO END DO END DO CALL SYSTEM_CLOCK(T(3)) C = A + B CALL SYSTEM_CLOCK(T(4)) FORALL(K=1:N, J=1:M, I=1:L) C(I,J,K) = A(I,J,K) + B(I,J,K) END FORALL CALL SYSTEM_CLOCK(T(5)) FORALL(I=1:L, J=1:M, K=1:N) C(I,J,K) = A(I,J,K) + B(I,J,K) END FORALL CALL SYSTEM_CLOCK(T(6)) do i = 1 , size(t_all) t_all(i) = t_all(i) + (T(i)-T(i-1))/TIC enddo enddo t_all = t_all / N_tries write(*,'(A,F0.5)') "DO CONCURRENT 1 : ", t_all(1) write(*,'(A,F0.5)') "DO CONCURRENT 2 : ", t_all(2) write(*,'(A,F0.5)') " ORDINARY DO : ", t_all(3) write(*,'(A,F0.5)') " ARRAY DO : ", t_all(4) write(*,'(A,F0.5)') " FORALL 1 : ", t_all(5) write(*,'(A,F0.5)') " FORALL 2 : ", t_all(6) read(*,*) i END PROGRAM
